LED under glove box/steering wheel help
Old Apr 12, 2010 | 12:07 AM
  #166
davidxu's Avatar
yeah. i didnt use thin copper wire. I think i used a 18gauge wire.
Old Apr 12, 2010 | 12:10 AM
  #167
toymachine2009's Avatar
your rear ccfl tubes for back seats where did you mount them? under front seats or under backseats?
Old Apr 12, 2010 | 12:12 AM
  #168
davidxu's Avatar
i mounted them under the front seats, but i really want to mount them front of the back seats. gotta find some room.
Old Apr 12, 2010 | 12:31 AM
  #169
why is it not good in the bottom of front seats?
Old Apr 12, 2010 | 12:33 AM
  #170
davidxu's Avatar
cuz the light doesnt really light up the rear footwell as good as if you mounted them under the front of rear seats.
Old Apr 12, 2010 | 12:59 AM
  #171
Im having problems hiding wire from back to front of sedan. any suggestions?
Old Apr 15, 2010 | 01:33 AM
  #172
Im ****ing pissed. I had all 4 lights lit up and working. Then One of the wires became disconnected from the harness so i went to put them back in and nothing they wont light up or nothing.
I tried disconnecting all 3 and tried to get one ccfl tube to light up by directly plugging that ccfl tube right into the harness and still nothing.
Nothing seems to be shorted car starts fine all lights including dome all work fine..
any suggestions???????
Old Apr 15, 2010 | 04:42 AM
  #173
a little help? I cant even get a single ccfl tube to light up now. I just have one connected to the harness and it wont light. Can there be a short even tho everything functions including dome lights and all?
Old Apr 15, 2010 | 05:39 PM
  #174
Bump
Old Apr 15, 2010 | 06:15 PM
  #175
davidxu's Avatar
try a 12 volt power supply other than the car. Make sure the cathodes tubes and transformer are working first.
Old Apr 15, 2010 | 06:40 PM
  #176
okay so if i took the red and black wire from the ccfl tube and put it straight to the battery on the black and red should they light up? Cause none did when i held the wire directly on the car battery.
http://www.svc.com/clk12wt.htm those are the lights I used. I had the two front lights wired in my car for 3 days until my other 2 lights came in. Tried to wire those and a wire popped out of the harness while installing rear seat lights and i went to tape it back in and none worked anymore
Did all the lights short? should I have used a power inverter for the 2 rear lights. BTW i wired it so each light had its own transformer (little blue box)
Old Apr 16, 2010 | 01:59 AM
  #177
Bump for Davidxu who is so helpful lol
Old Apr 16, 2010 | 11:11 AM
  #178
davidxu's Avatar
no problem
umm.. you need the blue box, for every 2 cold cathodes.
if you take the wire from the tube and connect it to 12v it won't work.
you need to connect the cold cathodes to the blue box, then from the blue box to the 12v.
imo, i would've bought the dual cold cathode kit. A single cold cathode kit would mean you are using 4 blue boxes, which will mean you're pulling a lot more power than required.
You just need 2 boxes. 1 for front, 1 for back.
connect 2 cold cathodes to each blue box
hope that helps
Old Apr 16, 2010 | 12:03 PM
  #179
no problem
hope that helps
yes thats what i meant i was taking the black and red wire that come from the blue box directly to the battery and none worked.
Also how did you use 2 ccfl tubes per blue box?? my cords are way to short to reach the 2nd blue box which is why i had to give each one its own blue box.
And I found that if I cut the wire before it got to the blue box stripped it and added wire to it to extend it that only lit up the ccfl tube half way. so I had to give each ccfl tube its own box because I couldnt extend wires to get to plug 2 ccfl tubes into 1 box.
Old Apr 16, 2010 | 12:06 PM
  #180
davidxu's Avatar
i'm not quite sure what you did, but this is how i did it.
I have two blue boxes, one for front, one for back. The red and black wires from those 2 blue boxes are connected to the dome light switches at the BCM harness. I extended one of the blue box so the blue box can seat under the rear seats in the middle, then 2 cathodes on each side.
for the front, my blue box is behind the center console, with 2 cathodes on each side.
my blue box has 3 ports, 2 for cathodes and 1 for power input
