LED under glove box/steering wheel help
Old Sep 5, 2010 | 01:16 PM
  #196
cboglio's Avatar
I'm assuming that the power came from the fuse box?
Old Sep 5, 2010 | 02:20 PM
  #197
toymachine2009's Avatar
Originally Posted by ChinkyChoy
I just installed mine today here's what it looks like i didnt use the CCFL tubes
i went the cheaper way and put these in:
here is what they looked like all done sorry for the crappy pics i took em using my phone
Wired the same way?
Old Sep 6, 2010 | 08:14 PM
  #198
ChinkyChoy's Avatar
nope they are wired differently i wired them into the fuse box you need to get an extra extension wire cause the wires on the lights are really short
Old Oct 20, 2010 | 12:14 PM
  #199
djfarhan's Avatar
just got mine in the mail! now i haveta get to installing it!
Old Oct 20, 2010 | 12:25 PM
  #200
pythonjosh's Avatar
If you have any issues post up. I'm pretty familiar with it.
Old Oct 20, 2010 | 12:35 PM
  #201
djfarhan's Avatar
i just need time now :P
Old Oct 20, 2010 | 12:36 PM
  #202
pythonjosh's Avatar
and some wire, wire snips, and a hot wire tester (or just an led with 2 wires).
Old Oct 20, 2010 | 12:37 PM
  #203
djfarhan's Avatar
i wanna hook it up so that it turns on only when i open the door, not on the whole time
Old Oct 20, 2010 | 12:48 PM
  #204
pythonjosh's Avatar
Let me know how that goes. I had that wired up in my car, and it seemed the ground connection for that was not a solid connection:
I will be working on it again. I am getting a third seat heater switch to use for my interior lighting as well.
I like the OEM button, and it is a 3 position button. One side is constant on, other side is door sensor, middle position is no connectivity.
Old Oct 20, 2010 | 12:54 PM
  #205
djfarhan's Avatar
OEM button?
Old Oct 20, 2010 | 12:58 PM
  #206
pythonjosh's Avatar
Seat Heater button. In the '03 6MT coupes (not 03.5) there is 3 switches in the center armrest console.
It is the only model of G coupe, and I think sedan as well, with 3 switch holders in the armrest console.
Old Oct 20, 2010 | 12:59 PM
  #207
djfarhan's Avatar
oh k, yeah in the instructions for the interior accent lighting kit, it has it connected to the gloe compartment connector.
Old Oct 20, 2010 | 01:50 PM
  #208
pythonjosh's Avatar
Actually it's the dome light in the BCM module. They will turn on when you turn off the car, and turn off when you lock/arm the alarm from the key fob.
Old Oct 20, 2010 | 01:51 PM
  #209
djfarhan's Avatar
hmmm ok, i'll double check
  #210
pythonjosh's Avatar
You're going off the instructions in this thread right?
