LED under glove box/steering wheel help
Old Apr 10, 2010 | 06:26 PM
  #151
ScottCash's Avatar
You know, I just ran a couple of wires to a fuse right off of the battery posts. Then through the rubber gromet, through the firewall to a switch under my steering wheel area. The actual lights are just LED strips. So with the switch, I can actually run them whenever I want. I like them so much I usually leave them on when I am driving at night.
Old Apr 10, 2010 | 07:04 PM
  #152
davidxu's Avatar
I have a sedan too. You can use the side foot plastic cover to hide the wires.
Old Apr 10, 2010 | 07:52 PM
  #153
toymachine2009's Avatar
where did you mount the ccfl tube in your sedan for the rear seats? I was thinking under the 2 front seats towards the back. What is the side foot plastic cover?
Old Apr 10, 2010 | 08:26 PM
  #154
davidxu's Avatar
like you know the trim along the side of the car when you open the door? where the INFINITI is? there is a plastic one that runs from the front all the way to the back. You can pull that off and put the wire under there.
Old Apr 11, 2010 | 12:11 AM
  #155
where would i tap into to add a switch to the lights? so i can have it both go on and off when door opens and closes and on when i please.
Everyone keeps saying they installed custom switches in their cig lighter etc. well lets see some of those pics..
Old Apr 11, 2010 | 12:24 AM
  #156
davidxu's Avatar
you tap it into the BCM harness by the driver foot well into the dome light circuit. Ill get a pic tomorrow
Old Apr 11, 2010 | 12:33 AM
  #157
i tapped into that for the light so do i just put a switch into the same wires i put the lights in?? do i need a resistor?
Old Apr 11, 2010 | 12:35 AM
  #158
davidxu's Avatar
if you tap it into the dome light circuit, you dont need anything, no switches, no resistors. everything is 12v. The lights will just come on whenever your dome lights come on.
if you tap it into the cigarette lighter switch, you need to have a switch unless you want it on all the time even when you're driving.
Old Apr 11, 2010 | 12:39 AM
  #159
well then something is wrong cause my floor lights do not go on when i flip the switch on for my dome lights??
now im really confused? My floor lights only come on when door is opened. When i turn my dome lights on they do not?
Old Apr 11, 2010 | 12:41 AM
  #160
davidxu's Avatar
yes that is normal. you tapped it into the circuit for the part where dome lights come on by itself. The dome light switch is on another circuit.
Your floor lights will only come on when you unlock the car, or open a door.
Old Apr 11, 2010 | 12:43 AM
  #161
ohh okay so my question is this then. Is there a way I can have it like that AND add a switch so they go on when I want not ONLY when I open a door?
So i can have both. Lights go on when door opens or unlocks. And a Switch so I can turn them on while driving if i want.
Old Apr 11, 2010 | 12:47 AM
  #162
davidxu's Avatar
yeah, of course. Someone has done it before, not me. So unfortunately i cant help you with that. I remember reading it up somewhere though. Try and find the original DIY thread about this.
Old Apr 11, 2010 | 12:48 AM
  #163
alright cool thank you for your help! Very helpful
Old Apr 11, 2010 | 11:50 PM
  #164
Can you use thin copper wire to extend the ccfl tubes wires?
Old Apr 11, 2010 | 11:55 PM
  #165
Scratch that it didnt work. it only lit up half the ccfl tube. I assume you all extended the wires on your lights as well cause they come pretty short.
