PIAA 168 LED HIGH INTENSITY BULB
Old Dec 14, 2003 | 01:01 AM
etang789's Avatar
hey i was looking for some 168 bulbs for my clearcorners and light strip and came across with this new PIAA 168 LED HIGH INTENSITY BULB on ....interesting i wonder has anyone try them yet, i wonder what color does it comes out? Anyone have pics with those bulbs? It is a lot more expensive then the PIAA Xtreme white..... well here is the link...
http://www.optauto.com/webstore/prod...k=yes&dept=436
2004 IP/Blk G35C 6spd navi/aero/prem
Old Dec 14, 2003 | 09:16 PM
SFLG35's Avatar
FGC President
Re: PIAA 168 LED HIGH INTENSITY BULB
i use the white white ones in my clearance strips. they light up the strip very evenly throughout. the color has a little bit of a blue tint to it but not very much. there is a post on here that has pics of the different colors. just run a search for LED and you should find it. ill look for it and see if i cant find it for you. my clear corners and another set of leds for them are on there way too. i would def go with the leds for the clearance strip cause some of the other ones dont light it up evenly throughout.
Daniel
5AT Coupe / DP / Willow / Aero / Premium / 3M Clear Bra / 5% Tint All Round
Old Dec 14, 2003 | 09:36 PM
SFLG35's Avatar
FGC President
https://g35driver.com/forums/showfla...view=&sb=&vc=1
here is one post there is anther one but i couldnt find it hope this helps
Daniel
Old Dec 14, 2003 | 11:22 PM
etang789's Avatar
Hmm i thought those LED bulbs are brand new?
Do u think it is worth to get these PIAA 168 LED HIGH INTENSITY BULB over the PIAA 168 XTREME WHITE bulbs?
it is like twice the price?and do they last? Since they are LEDs should last pretty long right??
Old Dec 14, 2003 | 11:33 PM
ericinmia's Avatar
i got the extreme white in my dome lights, and led white/white all over.... they are hot, led's are better than the extreme white... they match the car well, and look hot (white with slight, slight bluish tint)
Peace
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Dec 15, 2003 | 08:53 AM
SFLG35's Avatar
FGC President
eric: where else do you have the leds. im just goin to have them in the clear corners and then the extreme whites everywhere else. inside and for the reverse lights trunk and license plate. did you use the leds for the trunk and license plate lights?
Daniel
Old Dec 15, 2003 | 11:43 AM
G35_PR's Avatar
PIAA Extreme White are blue coat bulbs, I dont like those blue dot in my headlights, The LED white/white are clear led light and has pure white light.
Old Dec 15, 2003 | 12:16 PM
etang789's Avatar
oh really ? no blue dots? thanx for the info i will sure get them then
Old Dec 15, 2003 | 01:29 PM
DBLDN11's Avatar
I have the PIAA blue/white LED in my clearance and clear corners. I got the blue/white cause I thought with the blue I would get pulled over, but the blue/white's are even more blue than I expected.
Danielek
Aug 18, 2025 01:33 AM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
