quick help d2r and d2s bulb
Old Jan 24, 2008 | 08:08 PM
LazyAlex's Avatar
will d2s bulbs fit on my 2004 g35? or only d2r
Old Jan 24, 2008 | 08:10 PM
patman530's Avatar
you should use d2r only since you have the reflector housing
Old Jan 24, 2008 | 08:18 PM
redlude97's Avatar
+1, the d2s won't fit without modification either
Old Jan 24, 2008 | 08:37 PM
sfgr415's Avatar
+1 to the above. They will not fit without modification and D2S does not have the glare shield so those would cause glare in your reflector housings.
Old Feb 6, 2008 | 10:57 AM
osiris350GT's Avatar
What about the D2C bulbs
Old Feb 6, 2008 | 11:54 AM
redlude97's Avatar
they will physically fit but should not be used in reflector d2r housings because the bulbs do not have a ceramic glare shield on the glass which prevents glare. They will blind other drivers if you install them in your reflector housing
Old Feb 6, 2008 | 12:04 PM
One of my lights went out and I have an 04 Coupe, its becoming such a pain to find proper bulbs with the amount of choice available.
Dealer is quoting $320
I have been looking on ebay and came across Phillips 85126+ but its 5300k
should I go with 6000k d2c's? I don't care about blinding others as some ricers in their civics do that to me anyways.
Old Feb 6, 2008 | 12:13 PM
redlude97's Avatar
phillips 85126+ is not 5300k, its 4300k and are the same as OEM. Get those. Your logic is very questionable, don't expect to get help with that type of mentality, you should look in the mirror when you call those civics "ricers" as you are no different IMO
Old Feb 6, 2008 | 12:17 PM
How am I a "ricer" when I am replacing a bulb to OEM specifications?
anyways, apologies I didn't mean to come off as such a jerk.
I appreciate your help
one more question, which H4 matches with these phillips? when Im changing one I might as well change both.
Old Feb 6, 2008 | 12:27 PM
redlude97's Avatar
d2c is not OEM spec. good luck trying to match bulbs to OEM though, most people give up after trying multiple pairs and not having any luck. Another option is to go with yellow colored foglights so then you don't have to worry about matching. Luminics makes good colored bulbs
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
