OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 2, 2010 | 11:10 PM
  #1501
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by StormTroopa
if i don't have my fenders either rolled or cut by IA11, I will definitely take you up on that offer!!
not too sure about that fender finisher.. looks like you could pull a fender by accident.
well you obviously have to have some prior rolling experience to be able to use the finisher correctly. It's pretty self explanatory though. Heat the paint up really well and go one section at a time, slowly, making sure to overlap each section every time and you'll get the outcome you're looking for.
Old Aug 2, 2010 | 11:13 PM
  #1502
SN00P's Avatar
CLUB MODERATOR
yea i know what this is .. i have seen them before on the net ... i even found them brand new for like 50 bucks ... i think im going to order one ... how hard is it to use one cause i think i can figure it out ... ill test it on on my girls car first lmao !!!!
Old Aug 2, 2010 | 11:15 PM
  #1503
Look at my post above yours... that's exactly how you use it.
Old Aug 2, 2010 | 11:21 PM
  #1504
CG4DR's Avatar
it does seem self explanatory. just not sure i have the patience lol
Old Aug 2, 2010 | 11:23 PM
  #1505
SN00P's Avatar
CLUB MODERATOR
im ordering one tomorrow cause i have a little bit in the rear i need to do and i need to do my fronts .. plus cory ^^^ needs to get his all done ... i found one for 50 bucks im going to place my order :-) im sure ill get my use out of it
Old Aug 2, 2010 | 11:24 PM
  #1506
CG4DR's Avatar
can you really roll a cut fender?
Old Aug 2, 2010 | 11:27 PM
  #1507
r1forever80's Avatar
I dont know if it will work that well in the rear as the rear tends to have alot thicker sheet metal and spot welds back there. From my understanding is mainly for front fenders.
Old Aug 2, 2010 | 11:28 PM
  #1508
SN00P's Avatar
CLUB MODERATOR
thats not a roller !! its like a pincher ... since i have about 1/4 or maybe a little more left of my fender from being cut i think i have enough to bend it nice and flat :-)
  #1509
CandlestickPark's Avatar
ill Sedan
Yeah its used for fronts to pinch the fender flat. If you try to roll it flat you'll likely flare/pull it.
Old Aug 2, 2010 | 11:29 PM
  #1510
Depends how cut it is. Some shops will only cut half of the original lip because it doesnt rub too much. If that were the case, then yes you can roll it, its just a little more tricky.
If they cut all but a 1/4", you're better off cutting the rest off and sanding it down good so there are no rough edges. Then you'll definitely want to use some touch up paint or just have the lip professionally sanded and resprayed.
Old Aug 2, 2010 | 11:34 PM
  #1511
SN00P's Avatar
CLUB MODERATOR
^^ correct thats already been done its all touched up and sanded .. but as marcus said above its made for pitching .. im not trying to roll the rears ... im cut right at the edges exactly where the spot welds are at ... so all im really doing is pinching the rear to make the little lip flat ...
Old Aug 2, 2010 | 11:36 PM
  #1512
Where did you see if for 50 bucks? I could use one and add it to my collection of tools
Old Aug 2, 2010 | 11:37 PM
  #1513
SN00P's Avatar
CLUB MODERATOR
Amazon Amazon
and shipping will be like 10 bucks so like 60 the most
Old Aug 2, 2010 | 11:38 PM
  #1514
Johnnyone's Avatar
All this wheel talk, seeing fab's setup and Aaron 295 sparked my 10" and 11" setup again. Think if I get a new setup it would b 20x10 +20 and 20x11 +27. Thinking gs4 or schwert s2
S2
Gs4
Which one do u like?
Old Aug 2, 2010 | 11:40 PM
  #1515
SN00P's Avatar
CLUB MODERATOR
Gs4 :-)
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
