OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 5, 2010 | 10:09 PM
  #1621
SN00P's Avatar
CLUB MODERATOR
Originally Posted by StormTroopa
any pics of where they go?
https://g35driver.com/forums/suspens...it-sports.html
Old Aug 5, 2010 | 10:35 PM
  #1622
Gdup35sedan's Avatar
ENVautoDetailing.com
I also have SPC camber arms and bolts. I believe my camber is -4 or so, so I might have trouble getting the toe back in spec.
Dremel out the sub frame a tad more and you can get a little more out of it. Or you can get the adjustable trailing arms that have a slight amount of TOE adjustment, enough to get you 1/10th of a degree so you're at 0.00
Old Aug 5, 2010 | 10:37 PM
  #1623
CandlestickPark's Avatar
ill Sedan
^Good lookin' out Grant...thanks homie.
Old Aug 5, 2010 | 10:39 PM
  #1624
SN00P's Avatar
CLUB MODERATOR
hey marcus what is your front and rear camber specs right now ...
Old Aug 5, 2010 | 11:31 PM
  #1625
CG4DR's Avatar
are traction arms used to adjust toe further than toe bolts?
Old Aug 5, 2010 | 11:32 PM
  #1626
If you already have the toe bolts maxed out and still need more, then yes, adjustable trailing arms will give you that little extra you need.
Old Aug 5, 2010 | 11:49 PM
  #1627
CG4DR's Avatar
good then thats what i need. i want to run even camber so i hope i can get close to -2.0 on both sides..
Old Aug 5, 2010 | 11:53 PM
  #1628
You shouldnt have any problem with that. I'm dropped 3" and have spc camber/toe in the rear and i'm at -2 with plenty of room to go.
Old Aug 5, 2010 | 11:57 PM
  #1629
SN00P's Avatar
CLUB MODERATOR
and what are your specs of your rear ??
Old Aug 5, 2010 | 11:59 PM
  #1630
wheel/tire specs?
20x8.5 +20 with a 245/35. Can't even fit a butter knife between my tire and flattened fenders.
Front is 20x8.5 +20 with a 15mm spacer, so +5 and a 225/35
Old Aug 6, 2010 | 12:04 AM
  #1631
CG4DR's Avatar
my RR is at -2 but my LR is at -2.6 and i can't adjust it anymore without being able to get toe in spec
Old Aug 6, 2010 | 12:06 AM
  #1632
I'd try dremeling out the toe holes for the bolts again, maybe the left side didnt get done as much as the right side. It's worth a try, if it fixes it, it saves you $150-300 on adjustable trailing arms.
Old Aug 6, 2010 | 12:07 AM
  #1633
SN00P's Avatar
CLUB MODERATOR
very nice !! .. im waiting for my fender pincher to come in the mail any day so i cant start on the front so i can put my spacers on ... i need smaller tires so i can go more aggressive ... i have 245/35 front and 265/30 rears ... once i get my new tires ill be around +5 front and +10 rear :-) thats the only thing holding me back :-)
Old Aug 6, 2010 | 12:08 AM
  #1634
ill Sedan
Tried to get the rear to match the front. I'm guessing that I'm around -4 camber F/R. Haven't driven the car more than like 70 miles since I got the new tires, I'll know for sure once I get the car aligned.
Old Aug 6, 2010 | 12:28 AM
  #1635
CG4DR's Avatar
i don't have my toe bolt installed on the RR which is why i think i need the arms for the other side mainly.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
