4drmadness
close
- Join DateSep 2008
- LocationOrange County
iTrader Positive Feedback100
iTrader Feedback Score(60)
Liked:59 Times in 48 Posts
^ definetly man, gotta talk to you about something. pm you in a bit.
4drmadness
close
- Join DateSep 2008
hey snoop. i used the fender finisher today. came out GREAT. was able to pinch the fronts completely flat. gave me tons of clearance. i was also able to use it to pull the fronts about 5mm. cant really tell in this picture but this is the best shot i could get.
CLUB MODERATOR
very nice !!!! i had a problem with mine shipping when i bought it a bought 2 dont ask why and when i canceled it they had to send it back cause there were 2 of them in the box .. i should be getting it tomorrow i hope ... you should get about 5mm clearance from doing that i should have gotten a 25mm spacer instead .. :-) do you have a jack under your car or is that the height you ride at ???
wish i could. cant spend that much money right now. i am picking up some used df210s though so that will drop the front another half inch. which is good enough for me anyways
CLUB MODERATOR
the only thing you have to worry about with a 245 up front you cant slam it cause you WILL rub when you turn .. im dropped 2.5 or maybe a little more in the front and i don't rub at all anything lower then that i was rubbing big time everywhere when i turned... i need some smaller tires so i can really dump it .. since i cant dump the front i cant do the rear as well .. once i get smaller tires im going right down to 3'' or a little more :-)
that will look awesome. before today i would rub on any bump. not i dont rub unless i am turning and hit a bump at the same time.
CLUB MODERATOR
yupp :-) when i worked on my car last which was a few days ago i let my wheel lock key on the wheel and took off to test the coils and i lost the SOB on the road somewhere haha .. cause i want to drop the front a little bit but now i cant haha
That sucks. I know the feeling, actually happened to me to. But luckily I didn't go too far and as I went back to look for it, I found it on the rd. I was so relieved.
ooh. that does suck. it probably fell off pretty quick though. id just walk down the road a little bit and hope you find it
i know i could search this info but i'm being lazy today.. how much adjustment do trailing arms give?
here is my half *** teaser attempt. i know this is nowhere near agressive as you guys but its good enough for me
