OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 3, 2010 | 05:31 PM
  #241
OCG35's Avatar
Originally Posted by donpisto
If you're rubbing in the rear with a 245/40 I wouldn't go with a 255/35. I'd go with a 245/35 or maybe a 235/35 (don't know your wheel width).
With that much camber you shouldn't be rubbing, then again...what is your offset? Really hard to tell without knowing the rear specs.
I would rub alot on the inside, turned out my springs were compressed too much. If you jack up the car or put it on the lift, look to see if the tire hangs or the gap between the tire and the fender stays the same or approx the same. If its approx the same, your springs are compressed too much and it needs to be adjusted. Your next alternative is to hammer the inner fender well.
Where is it rubbing? Because if you dial in less camber, you'll have the issue even more if it's where I think it is.
Here is where I was rubbing because the springs were compressed way too much, now I hardly rub unless I have a full load or there is a steep dip.
you need these wheels to complete your aggressive VIP theme:
https://g35driver.com/forums/19-inch...-profound.html
I cant think of another G35 that could use these... but they fit the style you are creating...
Old Mar 3, 2010 | 05:41 PM
  #242
geesahtee5's Avatar
this guy has em too..
https://g35driver.com/forums/media-s...n-history.html
Old Mar 3, 2010 | 05:45 PM
  #243
OCG35's Avatar
maybe its not a good idea then...
I think they would have looked better on donpisto... but I'm not sure a look-alike wheel is a good idea (too unique a wheel to copy-cat)...
Old Mar 3, 2010 | 05:49 PM
  #244
GreenGoblin's Avatar
The goblin resurrection
Originally Posted by 4Dr.Madness.
DPE s-20?
Old Mar 3, 2010 | 06:19 PM
  #245
The Stimulation's Avatar
Yeah, I def need to changed it up..I was leaning towards going with that type of wheel for my next setup. Depending on what I do I may go back down to 19's so I can get a lower offset, unless I can achieve the same thing with 20's.
Old Mar 3, 2010 | 06:44 PM
  #246
4drmadness's Avatar
nopeee. jlines
Originally Posted by GreenGoblin
DPE s-20?
Old Mar 3, 2010 | 06:47 PM
  #247
STCLAIRWEST's Avatar
More pics!
Old Mar 4, 2010 | 01:57 AM
  #248
Fr3shIngredient's Avatar
lol teaser... POST PICCCS!!!!
Old Mar 4, 2010 | 02:05 AM
  #249
4drmadness's Avatar
sooon lol
Old Mar 4, 2010 | 03:18 AM
  #250
SlickG's Avatar
hmm, i never checked there. I think my car might be rubbing right there as well. My rear wheel is 19x10.5 with +22 offset.
What do i do if my springs are too compressed? if i jack up my car, it probably show about a 3" gap.
Old Mar 4, 2010 | 10:24 AM
  #251
Yeah, mine had virtually no gap. If it's compressed too much I'm not sure, it's basically the adjusting rings that need to be modified...whichever ones were used to adjust the height, then its actually the opposite one to do so...but then again I have true coilovers, so I don't know how that would work with your setup since you mentioned you have tein CS...what do those look like in the rear? How many rings?
One thing I can suggest is to contact swift or Eibach and have them make you some new springs with custom spring rates. I think it would be like 80 bucks each.
Old Mar 4, 2010 | 10:43 AM
  #252
G35Papa's Avatar
nopeee. jlines
SDMrL2 nice
Old Mar 4, 2010 | 12:47 PM
  #253
OCG35's Avatar
what is the hole in the shrub to the left of mailbox? Is that where you hide to spy on ppl?... when your you not spying from your wheel well of course
Old Mar 4, 2010 | 01:09 PM
  #254
4drmadness's Avatar
Originally Posted by G35papa
SDMrL2 nice
Old Mar 4, 2010 | 01:15 PM
  #255
Lol, crap you caught me....hehe. No it's a water meter.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
