OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Dec 11, 2010 | 12:55 AM
  #2626
4drmadness's Avatar
Old Dec 11, 2010 | 03:22 AM
  #2627
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
subscribed waiting for Blain to post up some pics
Old Dec 20, 2010 | 04:36 PM
  #2628
CG4DR's Avatar
What kind of offset would I need to run with a 20x10 at a ~2.5 camber in the rear with a 245 or 255 without pulling the fenders but rolled?
Old Dec 20, 2010 | 04:48 PM
  #2629
CandlestickPark's Avatar
ill Sedan
Probably somewhere in the low +30s with a 245. Brand of tire and how flat your roll is will make that number vary a bit.
Old Dec 20, 2010 | 05:26 PM
  #2630
CG4DR's Avatar
So what kind of camber with a 245 rolled flat with a +25? About -4?
Also what about a 20x9 +20 or +40 all the way around? Camber in front is ~0.5-~1.0 and stay with a 245 all around?
Old Dec 20, 2010 | 06:49 PM
  #2631
ill Sedan
That sounds about right. I would probably just do a slight pull so you didn't have to run as much camber. If you did a 5mm pull you could run ~-3.5 degrees of camber.
Do you want to do a non-staggered setup because you have an X?
Old Dec 20, 2010 | 07:01 PM
  #2632
4DGS's Avatar
Just finished taking the wheels a part, dropping the faces off to my metal guy this week if I find time!
I'll take some photos tonight as I am going to go clean the faces and polish the hardware.
Old Dec 20, 2010 | 07:34 PM
  #2633
CG4DR's Avatar
No. 2 reasons. 1 bc the rims I want don't have the best of specs and 2 so I can rotate
Old Dec 20, 2010 | 07:38 PM
  #2634
4DGS's Avatar
Rotating wheels is something that should not be heard in this thread.
And that means you need to look for better wheels!
Old Dec 20, 2010 | 07:44 PM
  #2635
ill Sedan
+1, unless you are doing a 10" width all around I wouldn't recommend running a non-staggered setup. A 9" wheel isn't wide enough for the rear, you're gonna be stuck running skinny tires to get any stretch on it.
What wheels are you considering?
Old Dec 20, 2010 | 07:57 PM
  #2636
CG4DR's Avatar
possibly axis angle.. haven't seen them done before on a sedan..
they have 3 widths 8,9,10
8 is +35
9 is +20/40
10 is +25
Old Dec 20, 2010 | 08:03 PM
  #2637
SN00P's Avatar
CLUB MODERATOR
so i decided im going to keep my 19s and the money i was going to use put it towards my BBK's i want but im still going to stretch my 8.5 and 9.5 tho with either 215/35 or 225/35 and for the rear 225/35 or 235/35 ... im looking to aim the fronts around +10 and rears about +15 ...so im going to keep doing my research :-)
Old Dec 20, 2010 | 08:08 PM
  #2638
4DGS's Avatar
8 is +35
9 is +20/40
10 is +25
Run 10s square
Chris, I'll talk to you when I get back from the gym tonight.
Old Dec 20, 2010 | 08:28 PM
  #2639
SN00P's Avatar
CLUB MODERATOR
^^ ok
Old Dec 20, 2010 | 08:29 PM
  #2640
ill Sedan
Chris, for sure don't do a 215/35, trust me! Blain is going to tell you the same thing. To pull off that tire size you have to be absolutely dumped and I know you wouldn't want to go that low.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
