OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 16, 2010 | 06:09 PM
  #286
Johnnyone's Avatar
Originally Posted by Get_some35
nice wx are sick!! and i think youll be fine (aggressive but not ridiculous) with the 20mm but its up to you!
im ok with aggressive i just want the same amt of poke in the rear. Specs on the rear is 19x10 +20
Old Mar 16, 2010 | 06:26 PM
  #287
The Stimulation's Avatar
No need to get an alignment (can't align the fronts anyway unless you have upper a arms).
With the splash guards being 1" above the ground that seems VERY low. I'd say that camber is closer to -3 degrees..it should be more than -2.4...but then again I was on 20's when i was at -2.4 and you're on I'm not sure what wheels..hard to say.
Nonetheless I don't think the alignment is necessary. I'd get the height figured out first and take it from there. See if you can borrow someone's spacers with built in lugs locally.
4dr.madness.... i didnt receive payment in paypal. whats the deal? quit laggin.
Old Mar 16, 2010 | 07:47 PM
  #288
Johnnyone's Avatar
Thanks for the input, unfortunately ppl here aren’t about fitment. Think im gonna try a 20mm and go from there.
It’s pretty cool when you like at your mirror and see this.
Here is the front that needs some work.
Old Mar 17, 2010 | 11:21 AM
  #289
04G35NYC's Avatar
Does this count as aggressive for a sedan ?
20x10 275/30/20 +40 offset as i was told by the last person i got these from.
Old Mar 17, 2010 | 12:01 PM
  #290
eurodre's Avatar
as soon as you go lower those will tuck more
Old Mar 17, 2010 | 12:50 PM
  #291
04G35NYC's Avatar
^ you are right, but i think it will stick out a little also.
Old Mar 17, 2010 | 12:53 PM
  #292
Gdup35sedan's Avatar
ENVautoDetailing.com
no it wont. i had the same setup. I was dropped 3" and it tucked right under the fender with plenty of room to spare. Put a 255/35 on there with a 25mm spacer, drop it 3" run -3 camber and roll your fenders flat, then you will have aggressive fitment.
Old Mar 17, 2010 | 12:56 PM
  #293
04G35NYC's Avatar
^ my fenders are flat hehe.
Old Mar 17, 2010 | 01:08 PM
  #294
eurodre's Avatar
troof.org
Old Mar 17, 2010 | 01:26 PM
  #295
kennymo's Avatar
I have the same setup with 1.5 and the tire and rim sits just inside
Old Mar 17, 2010 | 08:56 PM
  #296
gtrefever's Avatar
10+20 for sedans in the rear arent aggressive anymore if your lowered a good amount that will tuck with a 255. getsome35 he cant run a 25mm spacer in the rear ith -3 camber and be at -5 offset unless he has a big pull similar to mine and with atleast -4 camber. the fronts can use a 10000mm spacer.
Old Mar 17, 2010 | 09:05 PM
  #297
CandlestickPark's Avatar
ill Sedan
For those with a stock front that can dump their cars and not worry about their front bumper being too low.
Old Mar 18, 2010 | 08:44 PM
  #298
gtrefever's Avatar
haha, marcus sell your rims and go more aggressive
Old Mar 18, 2010 | 09:30 PM
  #299
4drmadness's Avatar
fever get ur new wheels!
Old Mar 20, 2010 | 07:08 PM
  #300
gtrefever's Avatar
hahah i hope to be back in the game by the next gtg.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
