OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Apr 30, 2012 | 06:42 PM
  #5551
CandlestickPark's Avatar
ill Sedan
They possibly could be Blain. I know someone else was complaining about not being able to get low enough on BCs with the 12K/10K setup. I wonder if the springs themselves are longer and that's the issue.
Old Apr 30, 2012 | 06:44 PM
  #5552
TORETTO's Avatar
BC Racing BR
Old Apr 30, 2012 | 06:58 PM
  #5553
Golden_Shower's Avatar
Stappy I had the same issues this weekend when I did mine, but its all fixed
Old Apr 30, 2012 | 06:59 PM
  #5554
TORETTO's Avatar
how do it baby
Old Apr 30, 2012 | 07:02 PM
  #5555
4DGS's Avatar
Hmm, BC is the problem here. They seem to add dead coils to add spring weight which in the end decreases how low they go. Not the way to do it.
Buy some HSDs or Stance, wish people would listen to me when I tell them that.
Old Apr 30, 2012 | 07:08 PM
  #5556
Originally Posted by ME GUSTA
how do it baby
2 hours of adjusting it and measure from the bottom of your sideskirt towards the back and not your fender to make sure the widebody is the same length.
Old Apr 30, 2012 | 07:26 PM
  #5557
TORETTO's Avatar
While jacking up the rear, I needed to run over two pieces of wood. This pushed the wheel upwards enough to match how the driver side usually sits. And it cambered just as much as how the driver side is when at that height.
So I think the issue is just the uneven height + the natural camber with it.
  #5558
The Stimulation's Avatar
Stance all the way for lows..just my 2 cents.
Old Apr 30, 2012 | 07:27 PM
  #5559
TORETTO's Avatar
Agreed. But seeing a couple cars that were low on BC's made me think these could go pretty low as well.
All I can do now is figure out why my ride height is not even.
Old Apr 30, 2012 | 08:13 PM
  #5560
Illuminati's Avatar
I just hope these coils will be able to let me go as low as i want to
Old Apr 30, 2012 | 09:16 PM
  #5561
TORETTO's Avatar
well shiiii.
that nut that secures the 17mm bolt, which you remove to lower the spring bucket is stripped.
its on the axle side so I can't get a socket in there. (at least my sockets, since they're not the shortest ones)
Old Apr 30, 2012 | 11:33 PM
  #5562
shawndon's Avatar
I'm having that issue with my fronts. I'm maxed out on threads so the only way I could go lower was to lower the spring. And I'm on 12/10. It seems no one running 10/8 is having this issue.
Old Apr 30, 2012 | 11:36 PM
  #5563
shawndon's Avatar
My next set will be Stance. I don't want to run into this issue with height adjusting again.
Old Apr 30, 2012 | 11:41 PM
  #5564
dz n.u.t.z.'s Avatar
just sayin!
Old May 1, 2012 | 12:04 AM
  #5565
shawndon's Avatar
How often do you rub?^^^
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
