OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jun 15, 2012 | 07:09 PM
  #5731
4DGS's Avatar
Originally Posted by Lowkeyg35
Ran a 215/35 upfront before didn't bother me at all
Clearly you were not low enough for them to affect you...
Originally Posted by jimmyboi860
What do you guys think about a 215/30/20 on a 20x8.5 up front? Only size I can get a hold of right now for my 20x8.5s to stretch. Currently running a 225/35/20. Running 255/30 in rears on a 20x10.
Just buy new wheels
Old Jun 15, 2012 | 07:34 PM
  #5732
The Stimulation's Avatar
Originally Posted by 4DGS
wasn't that fun, I wouldn't mind if I had been on 20s though.
Don't lie, it aint THAT bad. I actually had a tougher time with my stretch on the work wheel setup than the style 95's.
*edit: I take that back. with the 19's and the camber I had that brought me lower to the ground, the 215/35 on the 9 really damaged my car. Broken radiator and grinded the clip of my o2 sensor off...not to mention the outer shell of the oem cats and the usual scraping.
Old Jun 15, 2012 | 09:25 PM
  #5733
Lowkeyg35's Avatar
Being one of the first aggressive sedans on the board, actually the creator of this thread I'd say I was low enough. Though this post may get me banned oh well, blain we've chatted on Facebook I'm not going to put my name on here but a lot of these sedans are impressive and you know how I feel about your car. Only a couple sedans in this thread doing it right IMHO you and Marcus.
Old Jun 15, 2012 | 11:08 PM
  #5734
I was like...who is this guy? Hahaha.
Old Jun 15, 2012 | 11:49 PM
  #5735
CandlestickPark's Avatar
ill Sedan
C'mon Jeremie, you gotta stop creating multiple accounts man. Would love to have you back on here, you know what you need to do for that to happen.
Old Jun 16, 2012 | 01:36 PM
  #5736
4DGS's Avatar
Maaaaaaan, quit bannin the guy. He ****ed up and it's in the past.
But either way, 215s up front is no fun, triple no fun when you've got a glass kurookie!
Old Jun 16, 2012 | 01:39 PM
  #5737
4DGS's Avatar
btw, this is ride height. Even on the broken *** entrance to the track....
Old Jun 16, 2012 | 02:47 PM
  #5738
ill Sedan
"Straight up G" via Motor Mavens from Wekfest. Look closely you'll also see Mark and Chris in this pic.
Old Jun 16, 2012 | 04:16 PM
  #5739
JosansG35's Avatar
lookin' baws af!
Old Jun 21, 2012 | 02:32 AM
  #5740
iiiiiekoiiiii's Avatar
Old Jun 21, 2012 | 10:09 AM
  #5741
jookyshank's Avatar
I haz hugz to givez
spacers up front eko?
Old Jun 22, 2012 | 02:39 AM
  #5742
Yea. I used to think 10mm wouldve been too much.
I finally threw 15mms in the front. Now I feel like I couldve even went 20mm lol
Old Jun 25, 2012 | 05:06 PM
  #5743
djchris713's Avatar
Concept One RS8 Machined Black Finish
F: 20x8.5 +18 225/35/20
R: 20x10 +20 245/35/20
Fender rolled in the back
Old Jun 25, 2012 | 05:42 PM
  #5744
P10 WRC's Avatar
not really aggressive or low enough in the front
Old Jun 25, 2012 | 06:15 PM
  #5745
In regards to an above post of fitting an 11 et -15 in the front. It's doable. Here's an 11 et -12.
Run no less than -5.5 camber, run no less stretch than a 235/35, make sure fenders are pinched flat. No need for a pull really. You could to minimize negative camber or a super stretch, but I think it takes away from the stock body lines. Since the fenders up front are different from the rear (single walled and thin) I think it would be harder to get a smoother roll from it. Also, say goodbye to your sidemarkers. Make sure to run tires that run small or true as well. As for the alignment, your toe should be set up so that it gets the best wear out of it, which means any line or curve in the road, your car will pull into that direction. It's not too bad though.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
