OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jun 27, 2012 | 06:17 PM
  #5761
Gdup35sedan's Avatar
ENVautoDetailing.com
9.5+ 12 up front with 225/35 is easy, you'll want a 5mm spacer with stock camber arms and a 4" drop.
Rear you can do 235/35 with -5 camber and a roll +5mm pull on the rear fenders
Old Jun 27, 2012 | 06:30 PM
  #5762
DTRUONG_112's Avatar
Thanks for the input. I figured this set would be a good trial fitment to see how aggressive i want to go on my next set.
Old Jun 27, 2012 | 06:46 PM
  #5763
The Stimulation's Avatar
Originally Posted by DTRUONG_112
Well im not sure yet. The setup that i just picked up which is also my first set for the G35, 19x9.5/19x10.5 +12 all around. I ran extreme stretch on my last ride and i plan the same with this set. I plan on running 215/35 or 40 on all four. I was hoping -3 max up front and -4/5 max rear. Thoughts?
This
You could actually go with a 235/35 up front. I had a 20x9.5+3 with a 225/35 and still had room. Stock A arms. As far as stock upper A arm adjustment, you can't. Only rear camber you can. Although stock toe adjustment for the front you're good for whatever your camber needs are. I forget the 19" setup I had, but here's a pic:
I'll try to find out specs but the fronts were either a 9.5, 10, or 10.5 with a 235/40 or 245/35. Had low to mid single digit positive offset. That was with stock arms. Rear had a 255/40 or 255/35 on an 11.5. Single digit positive offset as well. But more I'm trying to find out is the front to better help you. I honestly think one Can run a 225/35/20 with a tire that runs like a Hankook with a 9.5 -5 and still not rub (on the sedan) and not need any upper a arms. With a 19 you could run a 9.5 -10 with a 215/35 with a tire that runs small like a Nankang.
Here's a couple pics of the 20x9.5 +3.
Second pic looks like it doesn't have the room, but with the first one you can tell that it does. It had a few mm left to clear the fender (after being rolled flat)
Old Jun 27, 2012 | 06:56 PM
  #5764
JosansG35's Avatar
there's sooo much room in that second pic ^
Old Jun 27, 2012 | 07:04 PM
  #5765
CandlestickPark's Avatar
ill Sedan
I have a 9.5 +5 on a 225/35/19 and I don't have any room to go more aggressive (not without adding more camber). Fenders pinched flat and flared from rubbing. My tires run on the larger side of true so I bet that is the difference.
Old Jun 27, 2012 | 07:05 PM
  #5766
JaE35's Avatar
Moderator
G35 Sedan
Originally Posted by the stimulation
Old Jun 27, 2012 | 07:06 PM
  #5767
JosansG35's Avatar
Marcus, don't you have aftermarket camber arms?
Old Jun 27, 2012 | 07:08 PM
  #5768
ill Sedan
Only out back. Stock A-arms up front. Natural camber from the drop is -3 up front.
Old Jun 27, 2012 | 07:10 PM
  #5769
The offsets and specs seem weak now with what i got haha.
Old Jun 27, 2012 | 07:12 PM
  #5770
ill Sedan
^Well the setups in this thread are among the most aggressive seen on a G35 Sedan. Not the type of setup you typcially see. More aggressive than some Coupes, particularly Coupes from back in the day LOL
  #5771
4DGS's Avatar
This is 235/35 on 10 +9 (equal to 9.5 +4)
Camber is roughly 3.5 at that point.
I've switch to a 225/35 and I'll be adding a 10mm to that though....
Old Jun 27, 2012 | 07:15 PM
  #5772
[QUOTE=CandlestickPark;6496486]I have a 9.5 +5 on a 225/35/19 and I don't have any room to go more aggressive (not without adding more camber). Fenders pinched flat and flared from rubbing. My tires run on the larger side of true so I bet that is the difference.
This is 9.5 +5 all around Marcus?
  #5773
JosansG35's Avatar
are those the specs for the front, 4DGS? I'm gonna run a 10 0 pretty soon so I think I'm gonna have to go with a 225/35 with stock a arms
  #5774
4DGS's Avatar
^ no 10.5 +17 out back
Josan, yes. My rear specs are 11.5 +16
You'll either need A arms or a front pull.
Old Jun 27, 2012 | 07:16 PM
  #5775
ill Sedan
That barely looks stretched at all Blain, what brand tires? Will look that much more gangsta with a 225 and more poke.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
