OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Nov 10, 2009 | 02:02 PM
  #121
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
hahaha one day I'm going to do a full gutted interior, 2 Bride Zeta seats built motor, bbk and call it a day! Straight Track G Sedan going against 1st gen IS300 ha! When I win the Lotto! One day
Old Nov 10, 2009 | 04:44 PM
  #122
oo G35x oo's Avatar
I may be asking this in a biased thread, but you guys know a ton on fitment. This spring I am looking to get some new wheels, I have decided on 19” Forgestar F14’s. I can’t decide on width however. I have an X so I want the same all the way around. I don’t like the staggered look or the stretched look, but I do like things to be more flush than stock, nothing too crazy though. I can’t decide between 19x9 or 19x8.5 all the way around.
How would a fairly flush setup do with 9’s in the front? I am at stock height right now, would I need to roll my fenders?
Any clues on what kind of offsets I would need to get a uniform flush look all the way around?
FYI, I live where there is a ton of snow, and even worse drainage ditches and spillways that make dropping the car a PITA. If I drop it at all it would only be ½” to an 1” because this is my DD and I don’t want to be freaking every time I pull out of a parking lot or driveway.
Thanks in advance
Old Dec 10, 2009 | 10:25 PM
  #123
ckkone's Avatar
Okay fitment Gurus...
Looking at a set of wheels in the following sizes
19x8.5 et22
19x9.5 et25
Will these buggers fit with a fender roll and what size tires do you recommend?
I'm thinking 235/35 and 245/35 would be a safe bet...
Old Dec 10, 2009 | 10:57 PM
  #124
The Stimulation's Avatar
They will easily fit with a fender roll. As for tire size, it depends on what look youre going for. 225/35's look great on a 9.5 for a nice stretch, it's what I got on my 9.5's up front...let me see if i can find pics...
Closer up (don't mind fitment of bumper and sidemarkers...they had a battle with the pavement and came out as a winner with some minor bruises ):
If you don't want as much of a stretch then stick to 225/35 on the 8.5 and 245/35 on the 9.5 (to keep the tires looking the same).
*edit: just to add..i was on a 9.5 +3 in front with factory camber and a little bit of a roll up front. The rear, different story, just roll it flat and you'll be cool.
Old Dec 11, 2009 | 03:26 AM
  #125
Tunerz_Store's Avatar
Originally Posted by GGG-G35
Ive been busy and havent had a chance to take quality pictures in a nice location. Here are a few pictures I took in my back yard. Ill have better pictures soon!
what all was necessary to fit the 05-06 lip on the nismo bumper?
Old Dec 11, 2009 | 06:44 PM
  #126
NjMatteSedan's Avatar
^ that looks so sick with the OEM lip on the nismo, especially on IP
Old Dec 23, 2009 | 11:18 AM
  #127
IPSECG35's Avatar
Fitment gurus! Looking to buy a set of Advan TCII (18 X 9.5) ET 35.
Looking to do a mild stretch on 245s.
Can someone send me a pic of how this might look?
Old Dec 23, 2009 | 01:13 PM
  #128
FlyingLumpia's Avatar
Search for a memember name bowzer and you will see a 18x9.5 with a 245 on there. But be warn you will have to slam your ride due to wheel gap.
Old Dec 23, 2009 | 01:28 PM
  #129
SDGenius's Avatar
always been a fan of ur ride
Old Jan 15, 2010 | 11:10 AM
  #130
StepUpG35's Avatar
what camber kits are u guys running in the back i was looking into SPC but i didnt know whether to just go with the "bolt" kit or the "arm" set up...
Old Jan 15, 2010 | 11:16 AM
  #131
CandlestickPark's Avatar
ill Sedan
^Get rear camber arms with toe bolts. You'll need both. If you just get camber arms then you won't be able to get your toe back within spec, which is important because without them you'll go through your tires very quickly.
Old Jan 15, 2010 | 12:39 PM
  #132
StepUpG35's Avatar
thank you candlestick any preferred brands?
Old Jan 15, 2010 | 01:14 PM
  #133
G SEDAN's Avatar
SPC rear camber arms + toe bolts will do just fine.
Old Jan 15, 2010 | 01:26 PM
  #134
jlo0109's Avatar
Lol for a second I thought you said SBF rear camber arms
Old Jan 15, 2010 | 03:13 PM
  #135
OCG35's Avatar
sorry to go off topic - but I posted this question in the wheel section and general G section (no responses)... maybe my sedan brutha's can help me (and this thread has the offset experts):
Originally Posted by OCG35
this is in the wheel section... but sometimes people don't visit there often - so I'm looking for help here too...
I have sedan with slightly flared fenders... no G sedan or coupe offset works right for me...
I realize I could get new custom offsets (or even existing offsets in some cases) - but I'm trying to avoid buying new again (the Volks I have aren't that old and I paid too much and waited too long to want to do it again)
So... Does anyone know what car might use the following sizes/offsets (so I can search for used)
within a mm or so:
8.5 +15
9 +21
9.5 +28
10 +34
tia
Also - does anyone know how many degrees camber equals 10mm? Or how many to 1"?...
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
