G57 Sedan Build Thread
Old Mar 29, 2018 | 06:03 PM
  #76
G35Drew's Avatar
G57
Cleaning up the terrible rusty threads so I have no issues lifting the subframe back into place
All clean and covered in anti-sieze
Old Mar 30, 2018 | 05:49 PM
  #77
G35Drew's Avatar
G57
All bolted back into place
Driveshaft on
Test fitting new crank pulley and figuring out the proper belt size
Been about a year in the making so far. Soon....
Old Mar 31, 2018 | 09:13 AM
  #78
Blue Dream's Avatar
I drove ttrank's car solo
Sick is all I can think to say right now.............
Old Mar 31, 2018 | 06:17 PM
  #79
G35Drew's Avatar
G57
Got the driver's rear put back together - Energy Suspension bushings everywhere, Kinetix camber and toe arms, new upper control arm, BC coils w/ Swift springs, Moog bearings and new hubs. That nasty caliper will be replaced as well.
Old Apr 1, 2018 | 05:34 PM
  #80
G35Drew's Avatar
G57
Forgot to put the backing plate on, the rear shoes wouldn't have worked without it
New PowerStop rotors, pads, and SS lines
Passenger side rear - tomorrow's project
Old May 2, 2018 | 08:51 PM
  #81
G35Drew's Avatar
G57
Nothing crazy to report. Life happens so I haven't gotten much done. The weather is warming up nicely so should be able to put more wrench time in. Got the ATI balancer torqued on. 235 lbs sucks. I sandwiched my left ring finger between the torque wrench and the frame when the drill bit I was using to hold the flywheel still slipped 🙄 probably gonna lose that fingernail.
Old May 3, 2018 | 02:30 AM
  #82
Equipped4dr's Avatar
Take your time. This build is awesome so far.
Old May 3, 2018 | 06:05 AM
  #83
Blue Dream's Avatar
I sooo can't wait to see this finished, gonna be beast.
Old May 6, 2018 | 01:09 PM
  #84
tiguy99's Avatar
So happy the first Gen Sedan's getting some love!
Man I too can't wait to see this finish out. Nothing but props!
Old Jun 12, 2018 | 04:35 PM
  #85
G35Drew's Avatar
G57
Got the summer tires mounted. 265/40/18 on 18x9.5 +38 out back and 235/45/18 on 18x8.5 +35 up front
Couldn't find a pretty place to run the heater hoses.
Decided to start wrapping the headers once they were already installed 🤦
Didn't like the factory terminals so I installed these mil-spec ones and a distribution block for the positive terminal
Old Jun 12, 2018 | 04:53 PM
  #86
G35Drew's Avatar
G57
Got a set of black housing eBay lights. They are just temporary. Gonna retrofit them to projectors once the car is driveable
The WEDS look killer in the sunlight
Vroom Vroom
What was left of the license plate light bracket. Grabbed a new one and got it installed with LED bulbs
Old Jun 16, 2018 | 06:21 PM
  #87
G35Drew's Avatar
G57
Cut the top off of a 240sx pedal and welded it onto the stock G pedal. Works great with the Z32 throttle cable.
Finally got to drive it! Only about 10 feet but it was awesome.
Alignment is all out of whack and I still need to roll the rear fenders
Old Jun 23, 2018 | 08:01 AM
  #88
G35Drew's Avatar
G57
I think the supposed low mileage GTO trans is trashed. I can only get it into 4th, 6th, and reverse when the engine is running. Luckily the engine/trans is easy to yank back out. When I return from vacation I'll pull it, see if anything looks wrong with the clutch, and possibly think about a level 2 rebuild if needed. I need to wrap the headers anyways, so it's not a huge deal to pull the motor
Old Jun 23, 2018 | 03:35 PM
  #89
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What happens if you start the engine with it in 1,2,3?
Old Jun 23, 2018 | 04:40 PM
  #90
G35Drew's Avatar
G57
It starts fine but as soon as I let out the clutch, it pops out of gear. If i hold the shifter in gear, it will grind like crazy until I push the clutch back in.
