G57 Sedan Build Thread
Old Feb 18, 2019 | 06:25 PM
  #106
G35Drew's Avatar
G57
I would like a GTO some day but that probably won't happen until the kids are out of the house. I have to go down the rabbit hole with each car I buy. I put a set of Acura CL Type S headers onto the wife's Odyssey
Old Feb 18, 2019 | 10:06 PM
  #107
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's cause the Odyssey is a badass vehicle. If I owned a minivan it would DEFINITELY be an Odyssey.
Old Feb 24, 2019 | 06:15 PM
  #108
G35Drew's Avatar
G57
Brought her out of the garage today. Drove for a few miles to put some time on the new clutch. I need to build my exhaust - open headers are no joke.
Old Feb 24, 2019 | 06:42 PM
  #109
G35Drew's Avatar
G57
Made a short start up and idle video. I don't think my cell phone mic will make any sort of revs sound good. Hopefully going to get time to work on building the exhaust soon so I can get some video of revs and pulls.
Old Feb 24, 2019 | 07:41 PM
  #110
cleric670's Avatar
BANNED!!!
I bet that thing terrifies pets and small children lol.
Old Feb 24, 2019 | 10:22 PM
  #111
Blue Dream's Avatar
I drove ttrank's car solo
Hell it terrifies me haha. Drew what's the small round thing on the passenger front door?
Old Feb 25, 2019 | 01:20 PM
  #112
G35Drew's Avatar
G57
That would be a small dent. I was idling the car in my garage a few weeks ago and my XMAS tree stand fell off of a shelf, hit the floor, and bounced right into the passenger door. What I get for idling indoors for too long.
Old Mar 2, 2019 | 04:33 PM
  #113
G35Drew's Avatar
G57
Just ordered two 3" flex pipes, a 3" 304 SS exhaust pipe kit, a 3" x-pipe, and a 3" dual inlet dual outlet Magnaflow muffler. Gonna try and build an exhaust next weekend if its not sub 32 outside. Plan is to attach the flex pipes to the header collectors. Merge those as far forward as possible into the x-pipe, run two short lengths of pipe into the muffler, and then dump the muffler somewhere before the rear diff.
Old Mar 2, 2019 | 08:28 PM
  #114
cleric670's Avatar
BANNED!!!
Planning on taking it to a shop to finish out the pipes to the rear or just leave it exiting under the car?
Old Mar 2, 2019 | 08:35 PM
  #115
G35Drew's Avatar
G57
I think it'll just dump for now. In the future if I wanna add a rear section and some tips, I'll do it. For now, the more racecar the better. I thought the G was gonna be my daily but I think she's going to turn more into a weekend warrior. I will not be installing A/C and the car doesn't have cruise control. Trying to daily a car without A/C in Florida is a no-no in my book. Might think about a rear seat delete, a harness bar, and some new seats in the near future.
Old Mar 10, 2019 | 07:38 PM
  #116
G35Drew's Avatar
G57
Started building the exhaust today. There is not a lot of room under these cars to run exhaust piping. One problem may be because I am laying on my back and at the mercy of how high my jack stands can go - it would be so nice to have a lift. The Magnaflow 3" dual inlet/dual outlet is way too long and too tall to fit anywhere underneath the G. This was my first time welding anything other than just some scrap pieces of metal together. My welds are not very pretty but they seem structurally sound. I used solar flux on the backside to avoid the "sugaring" that comes from a non-shielded TIG weld.
Today I completed - 2 V-bands welded onto the flex pipe sections, modified the x-pipe to make it narrower to fit fit in the transmission tunnel, and finished up the passenger side header to x-pipe connection.
It's too dark to take any pictures now but I will try and get some before I start working on it again in the next few days.
I just ordered 2 Dynomax mini bullet race mufflers. These will take the place of the gigantic Magnaflow that I had planned. It's going to be quite a bit louder but at least won't be as loud as open headers.
Old Mar 10, 2019 | 07:56 PM
  #117
cleric670's Avatar
BANNED!!!
TIG ?
Best advice I can give is to fold up a little piece of fire blanket so you can rest your hand on it directly next to what you're welding. It's all about that steady hand so you can keep the tip at the proper distance. If you are not supported properly then the distance fluctuates and you lose control of the puddle.
WATCH THE PUDDLE, don't watch the tip. Don't dip the tip into the puddle or you have to grind it down, you'll know if you do because it changes color and starts popping. Just watch the puddle and add fill rod as needed to keep the size consistent.
Old Mar 10, 2019 | 08:00 PM
  #118
G35Drew's Avatar
G57
Awesome advice
I am definitely a TIG noob. I saw a lot of progress from my first welds today compared to my final welds today. I think I had to re-grind my tungsten probably 15 times today
Old Mar 10, 2019 | 08:03 PM
  #119
G35Drew's Avatar
G57
I also wish I had a chop saw or band saw. I am having to make all of my cuts with a 4.5" angle grinder. I'm using a hose clamp as a guide to make sure I get a straight cutting line, tracing that line with a sharpie, then free handing with the grinder. Not the most ideal setup but it's working - a little.
Old Mar 10, 2019 | 08:10 PM
  #120
cleric670's Avatar
BANNED!!!
Check craigslist, you can usually pick up a used milwaukee portaband for a good price and it will last the rest of your life.
