Let the Modding Begin....
#76
As far as how good the alignment is, it depends on what your definition of the best is. My toe is in factory spec all around, and I think a toe number close to 0 is really the best thing for tire wear. Mine are between 0.03 and 0.09 degrees (really close to 0). For camber, my rear is at -1.35 degrees. I think that is a little more negative camber than factory spec, but I wanted a slightly aggressive alignment, but did not want to have too much tire wear (this is not aggressive by any means, but a good compromise in handling performance and tire wear). Something around -1 degree would wear a lot less, but gives up some performance. As I mentioned, the front cannot be adjusted. SPC is just now coming out with the first set of adjustable arms for the front, so the front could be a little lower. Mine is at -1.5 and -1.8 now, and I would like to get it down to -1 to -1.2. The factory spec in the front is under -1 degree. I am not sure if I care enough to install the adjustable front arms. I am going to wait and see how the tire wear is.
