07 g35x sputter when warmed up. No codes
Old Sep 24, 2020 | 12:24 PM
nick odonnell's Avatar
07g35x
Hi ,I'm new to this website and hope to find my why my g35 is sputtering when it's warmed up.i noticed when I turn my ac on the rpm go down, n when I turn it off the rpm go up.i noticed when I turn my ac on there is a noise on the front side.thetes slot of heat coming from underneath the hood when I drive and after driving maybe 5 min it starts to sputter/buck.sometimes I can put the pedal to the floor and it won't do anything then redline.it drives better when I ease into it.idk please help me.im really lost. New ecu4 new cam sensorCrankshaft sensorExhaust manifold gasketUpper lower intake gasketCoolantCoolanoil change.Throttle body both new$750 from nissan diagnosdiagnostics/relearn/ecu update.im lost..really love the car.please help.when I drove the car after warmed up it will buck / sputter and once it's sputter/ buck the cel blink on then off.but no codes....
Old Sep 26, 2020 | 07:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If the CEL blinks then IT'S THROWING A CODE. You need to leave your OBD2 scanner plugged in and go for a drive, pull the codes as soon as it starts blinking.
Blinking CEL means it's serious. Solid CEL means something is wrong but not catastrophic.
Old Sep 29, 2020 | 08:47 PM
07g35x
Hi cleric that for the reply. I've noticed that normal temp is supposed to be 185 .my slowly went up to 208 the more the temp goes up the more it wants to sputter.the cel block on off once it sputter/buck.then stays off the code is po507 with computer hookup up.changed ecu changed pvc changed thottle body .dealer did relearns...I'm lost.
Old Sep 29, 2020 | 10:47 PM
cleric670's Avatar
BANNED!!!
P0507 is the code for a high idle, probably a vacuum leak. Makes sense since the other major side-effect of a vacuum leak is an unresponsive engine or sputtering when you give it gas.
Usually it's a LOT worse when you floor it, takes about a fully second for the ECM to make adjustments in fuel ratio.
Old Sep 30, 2020 | 02:14 PM
07g35x
any idea where should I look.this started happening when I toke apart my thottle body to clean them then brought it to dealership to do all relearn and they said they can't get the idle to get back down ..do you think it might be to a worn out serpintine belt or one of the pulleys going bad.when I turn the AC off there's noise coming from the front side.when I turn on the AC the noise goes away..I'm Soo lost .I've been working on cars for a long time do my own build and all...this is probly the most difficult car to work on sooo far.thanks inadvane to any help.
Old Oct 3, 2020 | 11:18 AM
cleric670's Avatar
BANNED!!!
You may have damaged the worm drive gear in the throttle body, you're not supposed to work an electronic throttle by hand so if you were manually opening it to clean it that's likely what happened.
You can also try to relearn the throttle closed position, anytime the throttle bodies are unplugged they MUST be recalibrated for closed position, it's simple using the "pedal dance method" shown in the service manual, section EC - Engine Controls, near the front of the document under "basic service procedures".
As for the AC noise, is it just normal compressor noise or is it something ABNORMAL. It should have a loud CLICK as the magnetic clutch engages then it makes a slight "whirring" noise while the compressor is engaged.
Old Oct 5, 2020 | 10:05 PM
MurdaG's Avatar
It's got 2 doors 😂
any new updates boss?
MrDriver#50
Mar 23, 2020 08:37 PM
BuckeyeGuy
Jan 25, 2017 04:13 PM
timka86
Feb 12, 2009 11:16 PM
