Fried my starter
Old Apr 29, 2007 | 05:07 PM
codeflux's Avatar
Angry Fried my starter
damn remote start... started the car, came outside a couple of minutes later and heard the engine sounds very loud and weird. turned it right off - only to smell burning plastic smell. then it dawned on me that the starter must have been spinning with the engine. tried to start the car again a few minutes later - nothing... starter must be fried. calling AAA, will tow to infiniti of serramonte.
Old Apr 29, 2007 | 05:20 PM
jjyellow's Avatar
Daym, hope they cover it under warranty
Old Apr 29, 2007 | 05:30 PM
absolutg's Avatar
workin...
sucks to have that happen igor... let us know how it goes. good luck!
Old Apr 29, 2007 | 05:37 PM
Andy2434's Avatar
Ouch, Igor . . . I hope that you get it fixed in short time.
Old Apr 29, 2007 | 05:45 PM
OOOOA3's Avatar
Alumni****
doubt this will be covered under warranty, unless you got a real cool relationship with the service advisor or technicians. good luck!
Old Apr 29, 2007 | 09:10 PM
codeflux's Avatar
the warranty is out - i have 80+k on my car. besides, this is directly induced by an aftermarket item, so, i doubt it would be covered in any case... dropped the car off at the dealer... will let you know tomorrow what came of it.
Old Apr 30, 2007 | 11:42 AM
Sac2904's Avatar
Sorry to hear that, I hope it wouldnt' be so expensive to get it back on the road again. Please keep us post about what was wrong, I am sure some people have remote starter in their cars too...thanks!!
Old Apr 30, 2007 | 12:00 PM
JOKER's Avatar
CLUB MODERATOR
This is one very important function G is missing.
Car is expensive enough to have some kind of sensor installed that will shut starter down if engine is running already.
Good luck.
Old Apr 30, 2007 | 12:11 PM
codeflux's Avatar
it worked just fine for 3 years, and i use remote start daily, a couple of times a day at least. i will call the dealer around noon if i don't hear from them by then.
Old Apr 30, 2007 | 12:20 PM
Hi-TechG35's Avatar
Good luck. Keep us posted
Old Apr 30, 2007 | 12:46 PM
codeflux's Avatar
internal starter failure. talked to Pete. he said the damage may have been introduced by the extra heat generated by aftermarket headers (crawford headers) - i've had them since june of 2005, so ~25k miles.
they are overnighting the starter - it's gonna be ~$680 installed. ouch indeed. i've also asked about the TSB on the driver seat rail - it's not covered by the warranty, since the warranty is out - i'll let you know how much it's gonna be. i also asked them to quote me on new spark plugs - i've had Iridium Denso IKH16 (stock temperature) spark plugs since march of 2006, and the car has been idling rough progressively worse since then.
all in all - all this aftermarket crap is catching up with me... it's ok. this is a first mechanical problem i've had with my car (that wasn't mod-induced, per se), so, i'm taking it easy and not too upset. as always, i'll keep you guys posted.
Old Apr 30, 2007 | 01:05 PM
Kris79's Avatar
battle froggy
i am glad my uncle owns ASE and i get starters at cost. wierd that they would over night when most of those parts are stocked.
Old Apr 30, 2007 | 01:35 PM
codeflux's Avatar
JESUS JUMPING JACK CHRIST!!!
factory spark plugs = $300
driver seat assembly = $950
i told them to forget both, put some grease on the driver seat to see if it stops creaking. screw it. i'll just crank the tunes up a bit - and voila, noise is gone.
Old Apr 30, 2007 | 01:58 PM
trey's wife's Avatar
My horns hold up my halo
I'm pretty ignorant on these things but wouldn't something that was a TSB be covered anyway? I would think it should be if they know it is a known problem, of course, I don't get to make the rules.
Old Apr 30, 2007 | 02:09 PM
Kris79's Avatar
battle froggy
go to kragen for oem ngk plugs. like 7 bucks a pop
