High Engine Oil Consumption Rates
Old Mar 12, 2008 | 03:40 AM
  #211
Kris79's Avatar
battle froggy
Originally Posted by accordhybrd
Are you serious Kris, what are the gain differences from s/c to stroker?
i am thinking stroker is only around 80-125 hp. but for my driving habbits i wanna stay na. remember my turbo teg yeah that was no fun to drive when i hit boost
Old Mar 12, 2008 | 11:13 AM
  #212
accordhybrd's Avatar
I do remember the teg that was such a clean car, is it still around do you know?
John great info on the TSB, I would assume they changed it because the oil level is being checked only as soon as 1,000 miles by dealers.
Old Mar 12, 2008 | 07:40 PM
  #213
Kris79's Avatar
battle froggy
the teg was given the my ex cause i bought a tc as a new project..... umm yeah that thing lasted a whole 6 months before i dumped it hahahhaha
but my ex traded it in for a rsx then got bored and bought my old g35sedan then got bored got a s4 and now is in a s5 lol.
Old Mar 21, 2008 | 12:22 AM
  #214
awong's Avatar
damn i gotta check my car shiet... i still dont get oil consumption i mean why is it so bad and would it affect my car?
Old Mar 21, 2008 | 12:25 AM
  #215
Andy2434's Avatar
The short version . . . Your engine consumes large quantities of engine oil. Gone unmonitored, your engine will go "BOOM!"
Old Mar 21, 2008 | 12:39 AM
  #216
awong's Avatar
well i was reading a couple of pages and i heard this only happens to coupe and sedan MT i was wondering does this happen to AT for 06 sedan
I better check on it and my next oil change im gonna pay close attention to this
Old Mar 21, 2008 | 12:48 AM
  #217
MG35Coupe's Avatar
Originally Posted by frog
i checked my oil today its at half on the dip (about 3.5k miles) so my guess is no consumption for me /phew some luck finally...
btw MG35Coupe did u ever get your shifter fixed? when they replaced my tranny/clutch i had a similar problem where 5th gear wasnt top right, it was more of a top right, half inch to the left, then up. ended up the gear box or something was crooked they fixed it no questions asked now its good as new .
Hey sorry frog, been away from the forum for a bit, but to answer your question, no I haven't had the time yet due to work. I am glad it's a simple adjustment as it's throwing me off when I shift quickly (no pun intended), I get "stuck" right in that area you mentioned, lol.
Old Mar 21, 2008 | 01:01 AM
  #218
sfgr415's Avatar
It is always good to check your oil at least once a week. Just like you would check your tire pressure or coolants. It is always better if you catch things earlier than later.
But to answer your question, since you do not have the Rev Up engine, you are at less risk for the OC issue, however, there have been some cases on non Rev Up engines.
Old Mar 21, 2008 | 09:39 AM
  #219
Andy2434's Avatar
Originally Posted by V35 Skyline GT
Ironically, I've always and still do us my "B' trip odo to remind me when to check my oil level. Wish I knew a way to change the B to say OC
Andy, you may or may not appreciate this.
A friend of mine just got his V2 last week, did a break-in method I know on it and after ~300mi, it started to leak oil.
They found the oil filter housing on block to be bad and filter wouldn't seal correctly against it.
Yours still not leaking anymore? Hopefully not.
Geez, that must have drove your friend absolutely nuts. I feel his/her pain. It's good to hear that the leak cause/source was identified. I hope it is going to be a quick fix.
No, my car is no longer leaking oil. It has been some 400 miles since the oil leak was fixed and I had the oil changed. Tomorrow will be a telling day.
Hey, you and Pam have a great vacation, bro.
Old Mar 21, 2008 | 10:57 AM
  #220
Andy good luck with your oil change. I'm about 400 miles from my first 1000 mile check. I have spoken to Norman Taylor also. After my first check, will determine my next course of action.
Old Mar 21, 2008 | 11:48 AM
  #221
Kris79's Avatar
battle froggy
wow they really fixed something!!!!!!
Old Mar 21, 2008 | 12:23 PM
  #222
Andy2434's Avatar
Alan, I am about some 500 miles to the 1000 mile mark. Thus far, the jury is out until I can put more miles in on this last oil change. I have been monitoring the oil level very closely, needless to say.
Good luck to you with your process.
Old Mar 23, 2008 | 10:24 PM
  #223
awong's Avatar
well i just check yesterday and i just im like at 3/4 till full when i checked and i have about 2500 - 3000 miles on my oil since oil change good or bad?
Old Mar 23, 2008 | 10:48 PM
  #224
sfgr415's Avatar
If you are saying you are 3/4 full between the marks on the dipstick, you should be good. Alot of people with OC issues do not even get readings on the dipstick.
Old Mar 23, 2008 | 10:57 PM
  #225
awong's Avatar
well i do a couple time just to get a good reading... i did over like 5 time and at least the last 2 time it was around 3/4 full
