Osiris Install
Old Jan 22, 2008 | 01:13 PM
  #31
Klubbheads's Avatar
Originally Posted by ja3n3ss
higher rev=staying boosted longer... its not just reliant on a/m cams. the higher you go up the more the motor pushes... =T
I was talking about n/a cars. Even with boosted i doubt it will make the car any faster. Mine is raised to 7100 and the power cut off is at 6200-6300. Guess what happened when i shifted at 7100, I trapped 2mph lower and 0.2 second slower in a 1/4 mile run, compare to shifting at 6600rpm on the tach. I have seen many F/I dynos that the power cuts off at no more than 6500rpm. So if it does not help the acceleration of a N/A car i don't see how it would help a F/I without cams. I have actually tested this theory myself at the dragstrip.
Old Jan 23, 2008 | 09:55 AM
  #32
dofu's Avatar
20 Year Member
Hah! Yea... I meant a couple hundred.
Old Jan 26, 2008 | 08:45 PM
  #33
koolaid80's Avatar
New Dyno Numbers
Results after newest tune, lost a little bit of torque on the low end, but the car DEFINITELY pulls harder now, especially at the higher RPMs.
It was also a little warmer today than it was the last time I went to EIP (about 65 degrees outside today compared to about 55 last week).
Base
RWHP: 193.2
Torque: 175.3
Current
RWHP: 211.5 (+18.3)
Torque: 190.4 (+15.1)
For reference, a stock '03 Evo will pull about 180 rwhp on this dyno and a '06 Evo puts down around 220 rwhp. So in all, very respectable numbers, and a decent gain across the entire power band. I would highly recommend this to all Nor*cal G owners, as Paul takes his time to do the job right, and the numbers really speak for themselves.
Old Jan 26, 2008 | 09:38 PM
  #34
penelson's Avatar
Until proven otherwise by Dyno , this will be my tune. Hey when's that tax relief check comin ??
Old Jan 27, 2008 | 12:35 AM
  #35
tehdvd's Avatar
wow if i can get almost 18whp out of my automatic 04 then this would be tempting.
Old Jan 27, 2008 | 09:18 AM
  #36
dofu's Avatar
20 Year Member
Dyno chart is up, in the post right above yours.
Old Jan 28, 2008 | 12:43 AM
  #37
vodkarocket's Avatar
Modded Member
$700 installed/tuned is a good deal, but the gains don't justify the price.
I gained 35RWHP/30RWTQ with Unichip + tuning.
Old Jan 28, 2008 | 02:53 AM
  #38
koolaid80's Avatar
Don't forget that the tune was done on two different days (not an ideal situation I know, but it couldn't be helped).
The base dyno before the tune on the second day was ~190hp/~189tq; I should have asked Paul for that graph too, but it slipped my mind. It's amazing what a difference not dyno-ing on the same day makes.
Taking into account the lower base dyno on the second day, I would put the gains more in the region of +25whp, +20tq.
Vodkarocket - did you gain 35rwhp on your M3 with the unichip? And isn't the base price on the unichip over $700 as well (not to mention additional cost of dyno tuning)? This isn't an attack on your post, I'm just trying to clear up any ambiguity so I can understand where you're coming from. =)
Old Jan 28, 2008 | 04:00 AM
  #39
Modded Member
No, not the M3, my G35. Unichip was about $950 OTD, so the cost is more than Osiris but $/HP is higher.
I'll try and dig up the dyno-sheet, but IIRC the end result was 259RWHP for an all-motor 5AT sedan...
Old Jan 28, 2008 | 12:35 PM
  #40
tehdvd's Avatar
i see your sig saying (never modded), did you achieve that gain with stock exhaust, intake, etc?
Old Jan 28, 2008 | 04:08 PM
  #41
limeg35's Avatar
Hahaha...it also says his M3 is STOCK...thats like saying Bigfoot is tiny... , geeeess, these noob kills me.
https://g35driver.com/forums/northern-california/156455-never-posted-pics-my-new-car-here.html
Old Jan 28, 2008 | 04:19 PM
  #42
tehdvd's Avatar
https://g35driver.com/forums/showthread.php?t=156455
okay.... are all g35 owners dumbasses?
Old Jan 28, 2008 | 04:25 PM
  #43
Klubbheads's Avatar
did u just call urself a dumb a$$?
Old Jan 28, 2008 | 04:29 PM
  #44
tehdvd's Avatar
that answered my question. thanks
Old Jan 28, 2008 | 04:30 PM
  #45
Klubbheads's Avatar
^o, im sorry i thought u had a G35 as well.
Damn I must be really dumb.
