Other Regions United Kingdom, Japan, Australia, Middle East, Asia
UK Drivers?
Old Mar 9, 2007 | 01:33 PM
  #76
Dr Dave's Avatar
Originally Posted by garriem
David,
Is the manual you have an electronic copy ?
If so I'd appreciate a copy and I'd attempt to get some of it translated.
Garrie
sorry mate, its a large A4 manual (188 pages) with every option covered including veilside/top sceret cars etc, also i did not know they do a 4x4 version? did you??
but its only 2.5 ltr. (same G35 body)
it also lists the GT-R light and front end conversion, to change our cars to the 2008 GT-R.....hummm, note to self...start saving up
Old Mar 9, 2007 | 03:36 PM
  #77
urban's Avatar
Thought I would post as I am from Nottingham (born and raised) and moved over to Cali about 12 years ago.
Old Mar 9, 2007 | 05:17 PM
  #78
uk350gt's Avatar
Welcome
Have you been back at all?
Was over there last year for a holiday. Loved it. That's where I saw my first G and thought - I want one
Old Mar 9, 2007 | 05:19 PM
  #79
uk350gt's Avatar
Originally Posted by Dr Dave
"basic" servicing is the same as the 350Z (oil filters/plugs etc) but diagnostic's etc is totally different, i have had murders trying to get nissan to read and re-flash my ECU and my PCM boards following some dramas with wiring.
the problems seem to come from not lack of knowledge, but lack of the information on screen, telling the mechanics whats what.
even back and forwards from japan, seened to loose something in translation.
abbey motorsport seem to know the most about these.
i have a manual that explains everything about these cars, from modifications to full O/E parts, but its in japaneese................superb book, but as good as running out of toilet paper.
still, it will get better, with the likes of you and me taking our cars there....supply and demand, and all that.
good luck
david.
David
Would you take your car to Nissan in my situation or where else?
Thanks
Old Mar 10, 2007 | 08:03 AM
  #80
Dr Dave's Avatar
tough call.
there are a few considerations: firstly its always good to have main dealer stamps in your book, but most imported cars dont have any traceable service history (or its in japaneese)
secondly, as nissan dont have all the info and peramiters for our cars, it rearly is 6 of one and half a dozen of another.
thirdly, as long as you have some sort of history, from now on, regarding oil changes etc, i dont think you could go wrong.
to my mind a stamp from one guy..is as good as another.
your call
good luck
david.
Old Mar 11, 2007 | 06:54 AM
  #81
garriem's Avatar
Delimiter question
Anyone know much about delimiting the Skyline 350GT. i.e. removing the JDM restriction.
What are the implications of fitting a delimiter to remove the 112mph limit ?
If delimited what becomes the top speed ? (theoretical of course )
I've notice that at an indicated 90mph the engine is doing about 3000rpm,
I know the the red line is around 7000rpm but I remember my Subaru import, which was derestricted, maxing out at around 6500rmp in top gear even though the red line was 7800rmp. Anyone on here have the knowledge to comment ?
Cheers
Garrie
Old Mar 11, 2007 | 11:40 AM
  #82
Dazz67's Avatar
your missing out then
HKS do one ,I've one on mine works fine.
https://www.nitro-performance.com/sh...cat=388&page=1
or these guys do one ,don't no if its any good...
http://www.ncs-systems.com/prod/1458
Old Mar 11, 2007 | 01:23 PM
  #83
uk350gt's Avatar
Dazz
Did you import yourself then?
My car was already de-limited (purchased through an import company here). I have tested this out many time
Stu
Old Mar 11, 2007 | 01:26 PM
  #84
uk350gt's Avatar
tough call.
your call
good luck
david.
David
I agree with that. But I really meant in the event of an issue, is it worth taking to Nissan. You had some problems with them you mentioned, but I think you were trying to do some serious stuff with ECU etc.
I have an issue with SLIP light comming on sometime for no reason. Booked to take into Nissan next week, but expecting they will not have a clue, I might be wrong ??
Stu
Old Mar 11, 2007 | 03:32 PM
  #85
Dr Dave's Avatar
stu, i have taken my car to no less than 3 nissan main dealers...and they havnt got a clue....at the moment my car is in nissan guildford (woodbridge meddows) and all they were ment to do was re-flash the ecu to allow it to talk to the new pcm board (nissan O/E part) and its been there 4 days ????
its nothing like a 350Z that bit must be made clear from the offset, same engine and a few similar running gear bits, but thats where it stops.
2008...will be no problems, once they get the equptment/software etc, but at the moment , you have as much idea as they do.
so a competent indipendant guy would be just as good, if not better in my book, because hes not trying to copy 350Z info.
also de limiter is a must (are you kidding????)
i have the 155mph rev limiter also removed, and with mods she is pulling a indicated 172 mph (sat nav recorded speed)
you know it makes sence.
Old Mar 11, 2007 | 03:56 PM
  #86
uk350gt's Avatar
David
Where have you been going for servicing then? Is there a Service Light on our cars? I thought there was reading info on this forum (my previous car had this and needed to be reset each time).
What's this new PCM board for David? What is re-flashing the ECU exactly?
172mph Sat Nav, so what is that showing on the speedo?
Stu
Old Mar 11, 2007 | 04:05 PM
  #87
Dazz67's Avatar
Originally Posted by uk350gt
Dazz
Stu
No came through an import company,but delimiting was an option!!
who would want to keep the limiter
Old Mar 11, 2007 | 05:02 PM
  #88
uk350gt's Avatar
So the company put on an HKS delimeter?
Weather's getting better. Soon be time for a meet ??
Old Mar 11, 2007 | 05:20 PM
  #89
garriem's Avatar
Are there any dangers with the delimiter considering it's fooling the ECU into thinking it's doing no more than 112.
How does the ECU cope with managing the higher speeds e.g. fuel mixtures etc ?
Is it not risky just to fool the ECU?
So, does the JDM car aso have the 155mph rev limiter too?
Old Mar 11, 2007 | 05:45 PM
  #90
Dazz67's Avatar
yeah it was fitted when the SVA work was done..
yeah must sort a date,good to get out this w/end in the dry
