Engine Bay Pics*Post here*
Old Dec 21, 2009 | 11:49 AM
  #1681
SxExCx's Avatar
That's some ballin' ish right there!
Old Jan 2, 2010 | 07:46 PM
  #1682
Row2k's Avatar
20 Year Member
G35 Coupe
im finishing up my wire tuck of the main engine harness and having trouble depinning the MAF sensor, can anyone give me a tip on how to get the actuall metal pins out? I was able to take the black safety clip out from the inside, but the metal pins won't budge.
BTW gorgeous engine bays everyone !
Old Jan 2, 2010 | 07:55 PM
  #1683
k67p67's Avatar
I've never been able to depin the MAF plug.
Old Jan 2, 2010 | 08:02 PM
  #1684
bigc's Avatar
Wings Nation
1/4" split loom is wrapped around my MAF wires...that SOB plug won't come off
Old Jan 2, 2010 | 08:04 PM
  #1685
GreenGoblin's Avatar
The goblin resurrection
I got mine off, I will have to take a look at it tomorrow. I remember it being tricky.
Old Jan 2, 2010 | 09:22 PM
  #1686
Row2k's Avatar
20 Year Member
G35 Coupe
that would be great, thanks a lot. I really would hate to cut any MAF wires.
Old Jan 2, 2010 | 09:35 PM
  #1687
bigc's Avatar
Wings Nation
do not cut those wires
Old Jan 2, 2010 | 10:52 PM
  #1688
SxExCx's Avatar
why bother? you can only see about 1/2" of the MAF wires
Old Jan 2, 2010 | 11:08 PM
  #1689
Row2k's Avatar
20 Year Member
G35 Coupe
im wrapping all my wires as well as all the tucked wires in PET high temperature resistant braided sleeving, but since its not a "split" wrap it has to be pulled on so for me to pull it down the length of the harness I have to depin every single connector otherwise the connector is just too large to fit inside the sleeving as i pull it on. The only connector I have left is the MAF
attached is an example of what all my harnesses look like
Old Jan 3, 2010 | 01:18 AM
  #1690
k67p67's Avatar
Do not cut the MAF sensor wires. You'll regret it if you do.
You might also consider redoing those wires for the coil packs. It looks cleaner if you extend the 3 wires for each of the coil packs to the back of the block and sleeve each set individually. The branching you currently have looks a bit messy. Just my two cents.
Old Jan 3, 2010 | 12:38 PM
  #1691
ttrank's Avatar
Grocery getter
+1 I did all mine separate.
Old Jan 3, 2010 | 12:45 PM
  #1692
SleekStyle's Avatar
big c is doin it durty style!!!
Old Jan 3, 2010 | 01:15 PM
  #1693
Row2k's Avatar
20 Year Member
G35 Coupe
I think ill leave it as is; id rather have smaller wires branching out from the main harness as they approach the accessory / component as opposed to 10 smaller clusters running the length of the main harness before they reach the accessory. Just a matter of preference I suppose.
Also I do recall someone on here posting that both the MAF and throttle cables are not to be messed with as they are length/resistance sensitive. Thanks for the reminder nonetheless
Old Jan 5, 2010 | 12:34 PM
  #1694
SxExCx's Avatar
small chages...who sees them?
Old Jan 5, 2010 | 01:20 PM
  #1695
black a/c lines and bolts on timing cover, and real coolant delete!
