S tech and H tech people lets see em!
Old Jun 10, 2009 | 09:41 AM
  #301
jlin615's Avatar
Originally Posted by frozenmango
can someone answer my question??
can i run g s-techs WITHOUT a rear camber kit and still get an alignment?
No. Not too much out of spec though, about -2.0, spec max is -1.8.
Old Jun 10, 2009 | 09:43 AM
  #302
jlin615's Avatar
Finally some better pics of mine. G S-stech.
Old Jun 10, 2009 | 11:17 AM
  #303
frozenmango's Avatar
thats sick. is that with camber kit and alignment? rear spring mount? ^^^
and what is the dg dropped on?
Old Jun 10, 2009 | 11:49 AM
  #304
jlin615's Avatar
No camber kit, just alignment. No springmount mod.
That other car in my pics is actually a BS, dropped on HKS coilovers.
Old Jun 10, 2009 | 12:26 PM
  #305
does the passenger side hit higher than the driver side? cant really tell from the pics.
Old Jun 10, 2009 | 12:32 PM
  #306
SuperStezzyG's Avatar
+1 i end up doing s-tech on my G. My was at 2.1 left and right rear but my toe was ok.
Just gotta flip them tires.
Old Jun 10, 2009 | 02:27 PM
  #307
so i can get an alignment without a rear camber kit at all? and this would not hurt the rear alignment in the long run?
Old Jun 16, 2009 | 07:03 PM
  #308
Yosef's Avatar
I installed my stechs on friday and really like them but how long do these things take to settle? I know this isn't as low as they get.
Old Jun 16, 2009 | 07:48 PM
  #309
jlin615's Avatar
They won't settle too much from what you see right now. Wait a month, then get alignment.
Old Jun 17, 2009 | 01:39 AM
  #310
Yosef's Avatar
I got it installed at a shop and they already did alignment. Why does yours seem so much lower than mine?
Old Jun 17, 2009 | 09:32 AM
  #311
jlin615's Avatar
Go get another alignment in a month, numbers will change for sure. I did a very quick alignment the day I installed my springs, a month later went back to do a full alignment and numbers totally changed.
Did you get the Z or G stech? Don't count on the pics, because they are not often accurate compared to in-person.
Old Jun 17, 2009 | 05:42 PM
  #312
Yosef's Avatar
G-stechs, and I'm no comparing them only to pictures, saw other stechs in person and they seemed lower. I'll see how they look in a couple weeks.
Old Jun 17, 2009 | 09:19 PM
  #313
+1 get another alignment in a month. The numbers will change. Pretty much when it settles its not much of a difference very lil.. maybe 1/4 or lil more..
Old Jun 22, 2009 | 02:52 PM
  #314
LaConic2's Avatar
any1 have uneven rears on g stechs? my pass rear is a little higher ? used set so they're settled
Old Jun 22, 2009 | 02:58 PM
  #315
LaConic2's Avatar
jlin ur g is sex
