anyone slammed to the max on Stance coilovers?
Old Mar 12, 2010 | 09:29 AM
  #106
Johnnyone's Avatar
Originally Posted by nyckid
for you guys with stance coilovers, do you recommend getting the true coilover 12k/5k or the oem version at 12k/11k spring rates?
so confused, help me decide which one. I don't track my car. It's just for driving and cruising. But I want to be able to slam it as much as possible and have some comfort.
I asked the question about stiffer coilovers last wk, not sure if you saw the thread or not but it's located here.
https://g35driver.com/forums/brakes-...-feedback.html
As for it being slammed. Not sure what your wheel setup is but i went with the function and form II.
I'm currently tucking coupe 19's in the rear of a sedan and I still have another inch to go lower if i wanted to. I'm tucking the front also and have another 2 inches to go lower if i wanted to. I tried to go down another .75 inch last nite but rubbed the fender well when i turned and scraped the exhaust on big dips.
Is there a particular reason why you are set on getting stance?
Old Mar 12, 2010 | 11:13 AM
  #107
nyckid's Avatar
Heard that they were better quality all around. I never heard of the function and form coilovers until now.
But can someone please tell me if there are any differences between the true coilover and the oem version of stance? I am doing my research and still don't know which one to get. Some people say true coilover one drops lower while other people say they both drop the same. I need a definite answer please.
Old Mar 12, 2010 | 11:21 AM
  #108
GreenGoblin's Avatar
The goblin resurrection
oem style uses the factory bucket. Where as the true coil over does not, yo can replace the bucket with a toe aem for more adjusability. Either setup configured correctly will get you to the floor.
If you are just going to casually drive your car, go for the oem style. As the oem suspension is geared towards that setup.
If I were to do it again go with the gr+ and the 200mm spring. If you go with the gr+pro go with the 150mm spring as the helper spring and extra collars take up more room to get low.
Old Mar 12, 2010 | 08:52 PM
  #109
Frankieg35's Avatar
I was gonna get stances but they are sold out until may so im gonna get form and functions.. Im impressed with there specs.. And they go low as hell
Old Jun 26, 2010 | 10:26 PM
  #110
mitsuboost's Avatar
nice and low
Old Jul 3, 2010 | 01:05 PM
  #111
a.datthang.n's Avatar
i just got my stance coils last week. i been waiting since march, i got back order like crazy, first they told me i would get it end of april, then mid may, then first week of june. lol but it was worth it! here some pic when i just got them in. i didnt install the rear yet but this is at the lowest in the fronts
Old Jul 3, 2010 | 01:36 PM
  #112
Phil DeVtec's Avatar
^^^what's up with your paint?
Old Jul 3, 2010 | 05:19 PM
  #113
nyckid's Avatar
adatthang looks nice! can you do me a favor and measure from the highest point of your front fender to the ground and tell me how many inches it is? I want to see how many inches the stances are all the way down up front. Thanks!
Old Nov 2, 2010 | 11:11 PM
  #114
gtoor1990's Avatar
@a.datthang.n ... looks sick bro!
Old May 19, 2011 | 09:51 AM
  #115
Johnnyone's Avatar
Coils maxed out in the rear
Equals this
Would have thought i could go lower?
Old May 19, 2011 | 10:25 AM
  #116
Take the locking rings out, and you will gain some more, I got shorter springs on my true rear setup
Old May 19, 2011 | 11:04 AM
  #117
Johnnyone's Avatar
^ Gotcha, although i dont think i need to go any lower at the moment but will keep that in mind.
Old May 20, 2011 | 03:19 AM
  #118
4DGS's Avatar
I have a weird feeling the OEM multi link rear end goes lower than the true coil set up.
What's your preload set to Johnny?
Old May 20, 2011 | 08:48 AM
  #119
Johnnyone's Avatar
Preload is set what stance set them up as. Didnt want to mess with it.
One advantage that i have noticed with the true coils is you only need the spanner wrench to adjust the height, where as in OEM you have to a 17 socket and wrench to take out that lower suspension bolt.
Old May 20, 2011 | 09:00 AM
  #120
4DGS's Avatar
Definitely better for setting height.
