DIY: Airbag Reset Instructions for 03-07 G35 Coupe
Old Jun 8, 2016 | 03:11 PM
  #181
hockeyguy215's Avatar
Originally Posted by SFLG35
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
Perfect
Old Jun 14, 2016 | 06:29 PM
  #182
BigDre's Avatar
Flashing srs light 03 g35 sedan
Worked like a charm. Thx a lot!
Old Aug 20, 2017 | 08:53 PM
  #183
LuxuryMuscle's Avatar
Originally Posted by g35man04
Like the title says...i recently had an issue after installing my double din kit in which my airbag light came on and wouldnt go off..So i found this on the net and its an Airbag Reset Instructions that worked the first time i tried!!!
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Ignition Key Method:
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
Many thanks!!!! Worked the first time. Removed passenger seat to do some deep cleaning, srs lights came on. Found this thread, the rest is history!!!
Isn't the internet amazing?!!!
Old Nov 16, 2017 | 11:11 PM
  #184
PrinceHallG35's Avatar
Just bought an 03 G35X 3 months ago. I did this restart procedure 4 times and it went off. Thank you!!!
Originally Posted by DREPDOM
Yep, worked perfectly for me!!! Repeated 3 times. Thank you guys..
Old May 25, 2018 | 01:09 PM
  #185
DailyRunner's Avatar
Air Bag Light - Finally!
Thanks so much for this! It worked! Mine was flashing for a long time!
Rick
Old May 27, 2018 | 06:49 PM
  #186
AnonG35's Avatar
Unhappy
I have a solid airbag light. Is there any way to diagnose it?
Old Jul 14, 2018 | 09:03 AM
  #187
zizuo10's Avatar
OMG THANK GOD!!!! It work fckn awesome. Thanks to the original poster.
Old Mar 6, 2020 | 02:35 AM
  #188
BeckB's Avatar
Infiniti G37S
Originally Posted by LightsOut
your airbag system are in working order . If you want to test them go get an accident. lol
no need to worry.
LMAO!!! Great advice....Do you work for Infiniti? Perhaps in the sales department? 😜😂🤑
Old Mar 6, 2020 | 02:55 AM
  #189
BeckB's Avatar
Infiniti G37S
Originally Posted by Darr707
Omg, this worked perfectly. I changed cabin air filter and then the bag icon flashed nonstop. Was worried I messed up a wire or something. Glad you guys are on here.
I am shocked at how many people mentioned the light came on & started flashing after they replaced their cabin air filter! I replaced mine, (first time in my life to do it myself I might add), and shockingly that wasn't when mine began flashing. How in the hell I got that lucky is beyond me, as I didn't know what the heck I was doing at the time! For the SECOND time now, my flashing issue(s) started up after having dead batteries. Twice with my 2012 G37 Sport Coupe & at least once, that I recall, when I had my 2006 G35 Coupe...SO FREAKING ANNOYING & FRUSTRATING. My question is, WHY DOESN'T INFINITI, OR NISSAN, FIX THIS ISSUE?!?!? While they're at it, DO SOMETHING ABOUT CONNECTING ANDROID DEVICES VIA BLUETOOTH SO WE CAN LISTEN TO OUR PLAYLISTS THROUGH OUR CAR SPEAKERS STRAIGHT FROM OUR PHONES! Total....>(Without having to go out & buy special components.)
Old Mar 6, 2020 | 10:54 AM
  #190
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Because bluetooth streaming was basically brand new technology 15 years ago when these cars were made, it was practically nonexistent in ALL vehicles of that era, BT was for handsfree calling at the time not streaming music. Changes in technology later added more BT functionality with 2.0 and 3.0 hardware. Infiniti has updated their NEW CAR PLATFORMS as time went on but the 2006 G35 is a pretty old car.
As for your SRS flashing light issue, what was the actual code, did you put it in diagnostic mode to see what the actual problem was? There's over 50 different things that can go wrong with the SRS system to cause the light to flash, if it's ON diagnostic check fails for anything... the light flashes. Most commonly it's the passenger seat harness which there's a TSB for, easy fix.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
kenthung
Jul 21, 2015 05:56 AM
igking
Jul 19, 2015 01:12 AM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
