AC blows hot air above 60 deg setting
I drove ttrank's car solo
Received 1,486 Likes
on
It sounds like your headunit is starting to fail as do a ton of them. You can try banging on the sides of the upper part of the center console in line with the radio. Might help a time or 2 but you're going to need to replace the whole headunit including the A/C controls pretty soon if it's the issue.
on
Nope, the circuit board for the AC is part of the whole headunit assembly. You don't want to buy another OEM HU because it'll be prone to the same failure. Your best bet is to buy a new controller, new DD unit and the faceplate for it. Cruise over to the Audio/Video section and start reading, there's tons of info on it there.
on
Received 2,462 Likes
on
Coupe 6MT Premium RAS
on
infiniti g35 the air conditioning kept malfunctioning if I increased the temp higher than 60 it woul
