Need Help BAD!!!!!!!!
Old Dec 10, 2009 | 10:44 PM
x3v1l_350Gtx's Avatar
Hey guys i have a 04 g35 coupe on works S1 2 piece and im trying to take off my wheel but my stud is spinning and my lug nut got stuck.. I tried shotting it out with a gun and tried to hit it out tried cutting it off but its to stuck in there so i need to know some ideas??? really sad cause my dad tried to help and ****ed up the wheels so im just trying to just replace the studs
Old Dec 12, 2009 | 01:06 AM
lakerschamp2000's Avatar
take it to wheelshop and u should be fine.
Old Dec 12, 2009 | 03:10 PM
Scrooge's Avatar
I wouldnt put another new stud where the orignal one is spinning. That stud hole might be striped. Also have you tried pulling on the wheel and using a impact to remove the stud ?
Old Dec 12, 2009 | 11:47 PM
yea i tryed pulling it....that means i have to buy a new wheel hub....
Old Dec 13, 2009 | 03:55 PM
EnerOnE's Avatar
Sucks. Shouldn't be too bad of a problem to fix. I would take it to your trusted mechanic.
Old Dec 13, 2009 | 05:27 PM
Scrooge's Avatar
You might need one. If its the front wheel hub. Then its easy to replace.
Old Dec 15, 2009 | 02:50 AM
no its the rear wheel so its gonna be hard
Old Dec 15, 2009 | 04:09 PM
VolkZ's Avatar
drill the through the lug and break it, seems to be the only option left
Old Dec 15, 2009 | 04:10 PM
VolkZ's Avatar
put a socket over it and drill through the hole in the socket to avoid damaging the wheels
Old Dec 15, 2009 | 04:11 PM
VolkZ's Avatar
OR...u can take the rest of them off and have one person pry the wheel to put some pressure on the lug n stud
Old Dec 15, 2009 | 06:19 PM
geesteezd's Avatar
happened to me once.. twice actually. the second time i took it to a shop and got it drilled out, and they put a new stud for $90
Old Dec 16, 2009 | 01:56 AM
EGGPLANT's Avatar
are these OEM studs you have?
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
