FS: Energy Poly Bushings - Partial Rear Set New - Willing to separate
Old Feb 26, 2020 | 01:23 PM
chrismtb's Avatar
I bought a full set of rear Energy poly bushings and only installed 1/3 of them before deciding to sell the car. They are the black color and they are all new and unused.
The complete set was: https://www.energysuspensionparts.com/7.3122
I used the inboard-side bushings for the radius rod and front lower link rod, and the bottom spring cup and what is left are the ones for the upper control arms and the steering knuckles. Basically, I realized I couldn't press the knuckle and UCA bushings out with my small shop press and instead of taking the parts to a shop, gave up and put it back together.
I attached the instructions, so you can see which ones go where. This is a better version of it: https://www.energysuspensionparts.co...sion/17556.pdf
These are all listed as a complete bushing, e.g. 2 poly pieces and a metal sleeve. The parts are all here to do the same bushings on both sides of the car.
2x #2832 w/ 1.0x0.5x1.96" sleeve - see note below, can split up if you just need a single 2832/2833 pair
2x #2833 w/ 1.0x0.5x1.96" sleeve - see note below, can split up if you just need a single 2832/2833 pair
4x #2835 w/ 1.0x0.5x1.96" sleeve
2x #2836 w/ 1.0x0.5x1.60" sleeve
2x #2838 w/ 1.0x0.5x1.60" sleeve
To clarify, I have a total of 24 bushing ends (12 pairs) and 12 sleeves, which form a total of 12 bushings.
2832 and 2833 are the spindle bushings for the upper arm and according to the diagram, they are actually mixed - each side of the spindle uses one of each.
The rest are on the hub knuckle, which takes 2836, 2838, and 2x 2835 for each side of the car.
Energy does sell individual bushings through suspension.com, so if you need a couple of the missing ones, it might be worth it. The individual bushings worked out to $12-18 for 2 ends and a sleeve, so filling out the whole set from them with individual parts was going to be $90.
I can provide the details I got from them if you need any that I don't have.
$5 per bushing (2 ends and a sleeve). Willing to sell all as a set or break it up into groups. Free shipping if you are buying at least 4 of them, you pay the shipping on fewer.
I have 2.5 of the jars of grease that i can throw in with orders until they are gone.
If you aren't sure what you need after looking at the diagrams, I can try to help.
These would be great for anyone replacing individual parts and wanting to do poly bushings in them or replacing specific worn bushings.
Old Feb 26, 2020 | 01:34 PM
chrismtb's Avatar
To make things really simple, here's an annotated PDF of what I have and don't have (before selling any of them).
Green is what I have, red is what I do not have.
File Type: pdf
Old Feb 27, 2020 | 10:17 AM
Urbanengineer's Avatar
Very detailed! Thanks for following the sales rules. GLWS and enjoy your next car.
Old Mar 11, 2020 | 02:21 AM
chrismtb's Avatar
Still available
Old Jun 17, 2020 | 02:11 PM
chrismtb's Avatar
Still available, make an offer.
Old Aug 31, 2020 | 09:23 PM
Mad A's Avatar
Can you link the individual pieces needed to complete the set? This way we can come up with a total cost and make appropriate offers.
Old Sep 1, 2020 | 12:28 PM
chrismtb's Avatar
The part numbers are all there. Energy doesn't sell directly to the public, so you'd need to contact one of their resellers to have them get you individual parts. It's probably not worth trying to complete the set to save money. This would be useful for someone who needs to replace some individual bushings, someone who is replacing the parts that these go into and wants to upgrade the bushings, or for someone who has already upgraded the other parts and wants to upgrade the bushings in these parts.
Suspension.com (1.888.406.2330) is their reseller that is set up to offer individual replacement parts.
More specific part numbers for the sleeves:
15.10.623.39 - 1.25x.788x1.69
15.10.525.39 - 1.00x0.50x1.76
15.10.613.39 - 1.00x0.50x1.96
Old Sep 1, 2020 | 12:37 PM
Mad A's Avatar
That makes sense, thank you.
Old Mar 6, 2021 | 12:01 PM
chrismtb's Avatar
Old Jun 11, 2021 | 12:50 PM
chrismtb's Avatar
Still available if anyone needs any of these. Maybe you need to replace some of them or have a bad bushing or two on a stock setup?
deeliciousqueen
Steering & Suspension
Sep 18, 2017 04:55 PM
ivantheterrible
Feb 1, 2016 09:47 AM
Heero
Jan 3, 2016 11:56 AM
XDR-V35
Apr 7, 2012 08:48 PM
the_sedan
Dec 11, 2010 10:27 PM
