TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Can't fill tank all the way??
Old Nov 22, 2009 | 08:00 PM
  #61
dspec35's Avatar
gas fill issue
there is some thing called a shuttervalve cover which needs to be installed in the gas tank to avoid the fuel filler issue
go to the dealership with very low fuel in the car
reason being the tech would have to take you fuel pump out and install the shuttervalve in tank and and the lower the fuel level the better the tech will feel to work cause he will have to shove his hand in the fuel tank to install the cover (if the fuel tank is more than half full it will prettymuch burn/skin rashes the tech's hand )
Old Dec 22, 2009 | 10:58 PM
  #62
jimpier's Avatar
Ditto here. Gas tank not filling right issue AND fuel gauge all over the place
Old Jan 24, 2010 | 08:12 PM
  #63
spankey167's Avatar
add me to the list. lucky i have an extended warranty.
Old Jan 25, 2010 | 07:41 PM
  #64
skyvspecr34's Avatar
what kind of mpg was everyone seeing with this problem
Old Feb 4, 2010 | 02:45 AM
  #65
i just had this problem told the dealer about the tsb and they told me my sending unit was bad. wouldnt a bad sending unit throw a code.
Old Feb 16, 2010 | 12:23 PM
  #66
416dawn's Avatar
Here is first page of bulletin from October 30, 2008:
HARD TO FILL FUEL TANK
Applied Vehicles has been amended and the Classification was changed to FE. No other content has changed.
Please discard all earlier versions.
APPLIED VEHICLES: 2003 – 2006 G35 Sedan (V35)
2007 – 2008 G35 Sedan (V36)
2004 – 2007 G35 Coupe (CV35)
2008 G37 Coupe (CV36)
2006 – 2008 M (Y50)
IF YOU CONFIRM
The fuel tank is difficult to fill more than ½,
NOTE: Filling nozzle continues to click OFF when the fuel tank is more than ½ full.
ACTIONS
Install the Cut Bracket (cover) onto the Fill Limit Vent Valve (FLVV) inside the fuel tank (see Service
Procedure).
Old Apr 22, 2010 | 05:32 PM
  #67
tolyD's Avatar
has anyone tried replacing this problem part them selves???? how hard is it??
Old Sep 16, 2010 | 07:55 PM
  #68
fotodad's Avatar
Okay, so this is likely a dumb question, but here goes: Can this gas tank TSB be performed by a Nissan dealership, or does it have to be an Infiniti dealership?
Old Sep 18, 2010 | 09:56 AM
  #69
musti82's Avatar
mine started after i let the car hibernate for 3-4 month. 1/4 cant get filled. im out of warranty so as long as its 3/4 filled im fine for now , how much the shutter valve costs? just the parts?
Old Sep 19, 2010 | 12:42 AM
  #70
eagleee's Avatar
I had this problem fixed under warranty before and now I can only fill up 3/4. Does anybody know If they dealership will fix it again If the parts are bad? It hasn't been a year yet.
Old Sep 19, 2010 | 01:15 AM
  #71
chava12's Avatar
I have been going thru the same issue....but the best way that I fill the tank is to insert the nozzle and leave it alone not touch it all and it sucessfully fills the tank...my buddy is an infiniti lead tech and he gave me that tip...he also commented that fuel pressure is different from the states and japan that's why our cars tend to have that issue his best advice was not to touch it after we begin to pump gas.....
Old Sep 29, 2010 | 05:42 PM
  #72
cl9lover's Avatar
I have this issue - Going to go to the dealer tomorrow and see if they will fix it
Old Sep 29, 2010 | 06:04 PM
  #73
GR6RR's Avatar
easy to fix!
https://g35driver.com/forums/g-spot/...irdness-7.html
Old Sep 29, 2010 | 10:53 PM
  #74
iAM1SiCkG's Avatar
had this exact problem about 2 months ago went to the dealer and got all the valves replaced and all new fuel lines... thats the only way to fix it it used to drive me crazy leaving thr gas station and getting less than 190 miles to empty
Old Jun 3, 2011 | 03:07 PM
  #75
noxowner99's Avatar
ok guys let me tell you my story.
I was having this problem for some time and all i was doing was reading my KM because my tank was showing empty most of the time. Sometimes when I had a full tank the needle would go only at half tank mark. One day I made my calculations wrong and got stuck without gas. At the start I thought was my engine so I made many attempts to start and consumed all the gas in my tank, gas line and engine. Ran to the gas station and filled an emergency contenier with 5 liters. After that drove to the gas station and got a full tank. To be exact it was 74.02 liters. Since that day i never had any problem with my fuel gauge and it is measuring 100%.
