Gear for an AT5 dyno pull?
Old Apr 16, 2007 | 09:46 PM
JABG35x2's Avatar
I know I've seen this in the tech area, but was unable to put the right string together to get a search result. I'm getting the car in for its first dyno run this week, then one after the techosquare reflash. Guy with the dyno not to familiar with G's, so he might need help with this:
What gear should the AT be in for the pulls--3rd or 4th?
Thanks for the heads-up, will post the results (if I can figure how to get the scans of the print-outs on!) after the run with the reflash done.
Edit: probably got this in the wrong spot, but how do you post in the forum it should be in. Only time I can get a new post tab is in the G-spot!
Old Apr 16, 2007 | 10:12 PM
Nismo G's Avatar
Im about 95% sure its 3rd gear...
-Sean
Old Apr 16, 2007 | 10:42 PM
Triji's Avatar
3rd
Old Apr 16, 2007 | 10:51 PM
rookie's Avatar
4th is 1:1
Old Apr 16, 2007 | 10:58 PM
trey.hutcheson's Avatar
4th is 1:1, but 3rd is the preferred dyno gear because of the torque converter.
Old Apr 16, 2007 | 11:05 PM
rookie's Avatar
Aren't 4th and 5th full lock up gears? I've always dyno'd 1:1 like the manuals do.
Old Apr 17, 2007 | 02:08 AM
BracketRacerSteve's Avatar
4th Gear for 1:1, 3rd gear for higher dyno numbers
Old Apr 18, 2007 | 12:27 AM
OCG35's Avatar
3rd.
Old Apr 29, 2007 | 10:33 AM
V35 Skyline GT's Avatar
6MT Coupe
Most shops only will in 3rd and only 4th with manuals.
True, 4th is 1:1 with auto and 5th is 1:1 with mt's. I had 5 pulls done on my 6mt at a shop who would do 1:1. Had 3 in 4th and two in 5th, because I was curious if there was a difference.
There was no difference really between the two gears. My best pull was in 5th by + .5 to 1 hp, but results in the same gear will have a greater variance of that between all pulls.
My conclusion is, it doesn't matter which gear on 6mt's 4th or 5th. Autos torque converter could make a difference I suppose, idk.
Just my .02 and what was proven to me on my 6mt.
Old May 2, 2007 | 08:34 AM
Audible Mayhem's Avatar
its 4th guys, not 3rd. you want a 1:1 ratio when you dyno a car.
Old May 2, 2007 | 08:37 AM
owning a dynojet and playing around with all the time, that is not true on my dyno.
many many many pulls with every type of car with every type of mods done to it. usually the gear with more load and better exhaust escape per rpm works the best for higher numbers... this is on my dynojet of course
Old May 2, 2007 | 11:47 PM
OCG35's Avatar
dynapack 3rd for certain. No question about it.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Learned Hand
Oct 1, 2015 09:02 AM
