Ecu tuning 2002/2003 g35sedan (very technical)
Old Sep 19, 2012 | 06:31 PM
  #211
SurraTT's Avatar
Originally Posted by DVG
Do you mean the MAF sensor? Im new to all this so I wouldnt know if MAP is an acronym for another sensor lol
How does the UTEC compare to the haltech in terms of price and results?
Also, why does it sound like a waste? Has this sort of thing been attempted in the past?
Map= Manifold Pressure
UTEC and Haltech are similar but very different systems. Haltech is far better but the price is higher.
Yes this ecu has been out for a long time, Its during the "crappy" years for Nissan ecu's they really dont have any aftermarket support. The 04+ ECU's are the good ones.
Originally Posted by SDGenius
SupraTT, does ur Haltech PNP include a MAP sensor?
The Haltech unit has a built in map sensor.
Old Nov 1, 2012 | 12:35 AM
  #212
03GT35R's Avatar
Just read all 15 pages, glad I found this thread....just learned that my 10/02 (03) g35 5at sedan has they early ecu & up rev won't do anything for it.
Just installed Long tubes, ypipe, coupe mid pipe, cai & plenum spacer & catback system is ordered, &.now I can't tune it with a reflash....:-(
Can I just switch a 04 full engine harness & ecu into my 03? Has anyone tried it?
Old Nov 1, 2012 | 03:01 AM
  #213
Tolboothwilley™'s Avatar
I don't think anybody has tried it - be the first!
Old Nov 1, 2012 | 08:42 PM
  #214
03GT35R's Avatar
I will check into this 2mrw... I wanna make sure that i won't have to change a crap load of sensors along with swapping the harness...I know I can locate a harness & ecu with no problems...
Old Nov 1, 2012 | 08:55 PM
  #215
the 2004.5+ use wideband O2 sensors, so you want to make sure its a 2003-2004 that is the normal ECU
Old Nov 1, 2012 | 09:14 PM
  #216
03GT35R's Avatar
I ma try to find a late 03 or early 04 production date...
Old Nov 1, 2012 | 10:15 PM
  #217
03GT35R's Avatar
I ve located a ecu & harness, just gotta verify the dop, & make sure it's an auto rwd model...if its correct, I can pick it up next week & install next weekend...if it works, I ll be sending the ecu to uprev for a reflash...
Old Nov 2, 2012 | 11:34 AM
  #218
03GT35R's Avatar
Did anyone ever make a conversion harness from the early 03 ecu to the later 03, early 04 ecu harness?
Old Nov 2, 2012 | 11:44 AM
  #219
Jonathanbk483's Avatar
I have a queation about a aftermarket sound system i put a alpine type x in my 03 g35 its hooked up to a audio battery but when i turn it up really loud and the bass really hits hard there is hard shift shock can this mess up my transmission the sub is 1000 watts rms
Old Nov 2, 2012 | 11:46 AM
  #220
DVG's Avatar
DVG
how did you end up in tuner /dyno section...go to the electronics section haha
welcome to driver
Old Nov 2, 2012 | 12:09 PM
  #221
03GT35R's Avatar
^+1
lmfao
Old Nov 3, 2012 | 12:32 AM
  #222
LOL
upgrade your electrical circuits -
Old Jul 7, 2013 | 04:48 PM
  #223
DVG's Avatar
DVG
What other differences are there between 2003.0 sedans and the non misfit Gs?
Transmission? Engine? Anything else I should know about before boosting?
Old Jul 7, 2013 | 05:41 PM
  #224
SurraTT's Avatar
main thing is the ECU
Old Jul 14, 2013 | 03:14 PM
  #225
DVG's Avatar
DVG
http://www.nissanclub.com/forums/200...ml#post2949190
I found this regarding the MAF. It looks like we cant swap easily. Maybe an adapter harness can be made. I am posting this here both for future reference for myself and for you guys as well.
