Ecu tuning 2002/2003 g35sedan (very technical)
Old Jun 27, 2011 | 11:16 AM
  #106
ryanm8's Avatar
Nice Keep us updated.
Originally Posted by SurraTT
Trying to get this test harness done soon as possible. Ive got a TON of other car stuff going on right now!
Once the harness is made ill make a new thread on here to keep track of whats going on and how well it works with the early gauge and such.
Old Jun 27, 2011 | 12:05 PM
  #107
SurraTT's Avatar
Originally Posted by Eric@TCGMiami
I didn't do much to be honest, I just spent hours on the computer that the tech's use at Infiniti to find out all the pin-outs and ecu diagrams. I have an emanage blue and I wanted to be able to hook this up to the ecu patch harness so that I can at the very least just control fuel but when I noticed that I was experimenting with a 1,000.00 ecu I quit the minute I saw the engine didn't start and then I had to reset the ecu to get it to crank.
I honestly gave up on that idea quickly.
but here is a picture of the harness.
Hold up. By lookin at that harness its just a simple patch harness. Something ive been selling for a while now.
So you got a patch harness and wanted to wire in a EMB?
I thought you where swapping to the newer style ecu, the black connector ecu.
That patch harness is cake, ive been making those and wiring UTEC's to them for maximas/altima/sentras with 3.5 swaps/ would even work in these early G's
Go to my site www.VoltageDrop.net
Im confused now man, what ecu did u purchase brand new? Black or grey connector?
What im looking to do is replace the old style ecu (GREY) with the new style ecu (BLACK) the black connector ecu UpREV osiris works with it.
Thing is with a patch harness i can make the early g sedans run on a haltech/utec/ w/e just like im doing for the maximas.
Old Jun 27, 2011 | 12:21 PM
  #108
Eric@TCGMiami's Avatar
Well my initial goal was to make a patch harness for a emange or an SAFC..
Then I thought, well heck I'd love to play with the timing and knock control.
Then BAM BUMMER!
Then after much thought, I decided well, why not just get the newer connector make a patch harness from the OEM sedan wiring to the new ECU and if needed keep the old ecu to make whatever is needed to accomplish without the dash lighting up like a Christmas tree.
Old Jun 27, 2011 | 12:29 PM
  #109
SurraTT's Avatar
Then BAM BUMMER!
ok i see, so did you ever hook up a black ecu connector to your car?
With that patch harness like it is in the pics its impossible to hook up a black ecu to it.
Old Jun 27, 2011 | 12:43 PM
  #110
No black connector ecu ever... just the shitty new ones...
Old Jun 27, 2011 | 01:04 PM
  #111
SurraTT's Avatar
So the Brand NEW ecu you got was a Grey connector ecu??
sorry im still kinda lost on it. haha
Old Jun 27, 2011 | 01:05 PM
  #112
NFSP G35's Avatar
? = 2B || !2B
^+1
Water u sayin?
Old Jun 27, 2011 | 01:44 PM
  #113
NO BLACK ECU.... EVER
Just the grey OEM.
Patch cable never worked.
Old Jun 27, 2011 | 01:48 PM
  #114
SurraTT's Avatar
Just the grey OEM.
Oh ok, hmm whats the point of the new ecu then??
Anyway, the Adapter harness will adapt the early g ecu harness to the new black ecu.
I thought that's what you had this whole time.
Old Jun 27, 2011 | 03:54 PM
  #115
ryanm8's Avatar
No one has tested out using the adapter harness with the new ECU (black connector)?
Old Jun 27, 2011 | 08:58 PM
  #116
NFSP G35's Avatar
? = 2B || !2B
^guess not. I thought that's what Eric did, but apparently not
SurraTT did, but that was on a Maxima, which has several key differences from the first generation G.
Old Jun 27, 2011 | 10:54 PM
  #117
I wish I could get my hands on a patch harness and the new style ecu... I'd give it a shot but unfortunately these days I am pressed for time with the strip clubs I have invested into
Old Jun 30, 2011 | 11:32 PM
  #118
SurraTT's Avatar
Thats right! The early g does have the grey connector ecu BUT the ecu is very similar to the black connector ecu.
While on the Maxima the grey ecu has quite a bit more difference than the black.
This is a good thing for you early G's!
Doing a test setup soon. This is possibly something i can offer there is no way of knowing at this time tho.
Old Jul 14, 2011 | 12:09 AM
  #119
Ok, So what if I buy the following items:
2004+ ECU
2004+ Wiring Harness
2004+ Console (Dash with Speedo and Tach)
2004+ Radio-A/C Controls
Will I need ANYTHING else to convert the car from 03 to 04+ ECU?
Old Jul 14, 2011 | 12:12 AM
  #120
NFSP G35's Avatar
? = 2B || !2B
^Might want to hang tight for just a couple days.
I just got the experimental adapter harness in the mail today, but I haven't had a chance to test it.
Hopefully I'll get a chance tomorrow afternoon.
