Osiris Tuned: Dyno Sheets FTW!
Old Jun 10, 2013 | 10:47 AM
  #211
3000vr4tt's Avatar
Originally Posted by Dark-Knight
That's crazy, I had completely different mods on my G but got the same numbers after tune when I had the stock engine. I've since replaced the whole engine and just got retuned at 6psi. I still want to do the fuel return mod and install a MAF GT before I push beyond 400whp.
whats the fuel return mod?
Old Jun 10, 2013 | 10:58 AM
  #212
seymore4's Avatar
m56
I've got a brand new MAF GT, shoot me a PM when you need it
Old Jun 10, 2013 | 11:06 AM
  #213
Dark-Knight's Avatar
Word. How much you lookin to get for it?
Old Jun 10, 2013 | 11:12 AM
  #214
It's an upgrade to our fuel system routing. It provides better flow for high HP VQ cars. The OEM set-up doesn't work well with high boost.
Old Jun 16, 2013 | 01:14 AM
  #215
Shurik355's Avatar
My Osiris ECU Tune...
07 G35S Sedan 5 AT
Full Exhaust, HFCs, CAI, and this ECU tune.
Video link is here >>>
280 HP and 250 Torque.
Old Jun 20, 2013 | 09:48 AM
  #216
ROD350GT's Avatar
http://i48.photobucket.com/albums/f2...81496708_n.jpg
Old Jun 24, 2013 | 06:50 PM
  #217
RedG's Avatar
<--12 More Years
Finally I flashed my car with the Osiris tuned this weekend.
My current mods installed before it was flashed (2004 6MT), it did 244whp:
Injen CAI, Motordyne 5/16, ART Pipes, Motordyne TDX2 Full 3" True dual version
Same mods with the Osiris flash, 250whp
It gained 6whp after the flash. Are this the normal gains, or do you guys think I can get some more out of it?
After researching here on driver I see almost everyone gains well over 10whp.
BTW check engine light came back on again, =( I though it would be gone after the flash.
Thanks for your input.
Old Jun 25, 2013 | 10:36 AM
  #218
seymore4's Avatar
m56
Originally Posted by RedG
It gained 6whp after the flash. Are this the normal gains, or do you guys think I can get some more out of it? .
Absolutely no way to tell without seeing the Dyno sheet, gains under the curve are more important than just peak HP
Talk to the tuner, he should be able to take care of that easily
Old Jun 25, 2013 | 05:30 PM
  #219
RedG's Avatar
<--12 More Years
I did the flash myself with the tune from Uprev, spoke to them today and they told me that I had gotten the basic tuned map, and to email them the datalogs for a more specific tune. I will try to datalog the car tomorrow.
Here are the dyno sheets I will definitely appreciate the input
Attached Thumbnails Osiris Tuned: Dyno Sheets FTW!-dyno2.jpg
Old Jun 25, 2013 | 05:49 PM
  #220
seymore4's Avatar
m56
Then you're just running on the base tune.. You need to dial it in now with the datalogs
Old Jun 25, 2013 | 05:58 PM
  #221
RedG's Avatar
<--12 More Years
Cool hopefully the gains will be better, I will definitely get them those logs asap
Old Jun 25, 2013 | 08:37 PM
  #222
DragonBoas's Avatar
Interested to see what more you get after a more specific tune. I've got roughly the same mods plus a couple more so hopefully that will give me an idea of what to look forward to after I get the uprev tune here shortly.
Old Jun 25, 2013 | 09:32 PM
  #223
seymore4's Avatar
m56
You should pick up around 10-15 whp with a proper tune. The attached dyno is pretty typical for a non revup 6MT with spacer and exhaust (I tuned it FYI)
Attached Thumbnails Osiris Tuned: Dyno Sheets FTW!-joe-dyno.jpg
Old Jun 26, 2013 | 06:58 PM
  #224
RedG's Avatar
<--12 More Years
Awesome man those are the gains I been seeing on the forums more or less with the Osiris, I sent them the datalogs today, let see how it does when it come back.
Just to know If I sent you my ROM and datalogs could you optimize it?
Old Jun 26, 2013 | 09:02 PM
  #225
seymore4's Avatar
m56
I could.. But you've got 3 free etunes from uprev, might as well use em up
