Uprev Q&A
Old Sep 12, 2020 | 04:49 PM
  #136
seymore4's Avatar
m56
You do not need an LC1. That's the whole point.
Old May 4, 2021 | 11:01 PM
  #137
Tj Northrup's Avatar
Z1 spacer Takeda cold air intake dna catback exhaust
Tune
Originally Posted by seymore4
I'll PM you, this is mainly a general information/ ask questions thread, not a FS thread
tried pm u about remote tuning
Old May 20, 2021 | 06:37 AM
  #138
r0llinlacs's Avatar
V35 6MT revup
Hey guys, I got my 05 revup dyno tuned and paid for the ARC license but honestly I'm not sure if my tuner knows what he's doing.
He didn't even know about MAP switching and he can't seem to make a burble MAP. He says the timing changes he makes get reverted back by the ECU. It should be 4 degrees but keeps going back to 15 degrees.
I wanted the ARC features but when I left he didn't turn any of them on except launch control, only the first step working.
Flat foot shifting, if I understand correctly, when I shift with my foot still in the gas pedal, the RPMs shouldn't rise by more than 50rpm (the default setting), correct? He said it's turned on but when I try FFS it just revs up to the redline like normal...
Also they keep saying the 2nd step of the 2 step launch control isn't for NA cars.
So can revups get burble MAPs? What's the deal? I paid a **** ton of money and barely got half of what I wanted.
Old May 20, 2021 | 08:36 AM
  #139
seymore4's Avatar
m56
Sounds like whoever tuned your car has no idea what they're doing
Old May 20, 2021 | 10:08 AM
  #140
r0llinlacs's Avatar
V35 6MT revup
I mean he was knowledgeable, but it just seemed like he wasn't very experienced with uprev, and he said he'd done burble MAPs on a few other Z's and G's but mine wouldn't work.
Old May 21, 2021 | 09:21 AM
  #141
seymore4's Avatar
m56
Just because someone is a good tuner does not mean they know how to tune with Uprev.. If they never took the time to fly down to Austin and get trained they're just figuring it out on their own
Old Sep 20, 2021 | 03:48 AM
  #142
Mshaneish1's Avatar
2004 Infiniti G35
Clarification please. 2004 g35 can be remotely tuned?
Old Sep 20, 2021 | 09:45 AM
  #143
seymore4's Avatar
m56
Correct. 2004 and newer come with factory wideband O2 sensors so we can see everything we need to tune it remotely. 2003 models we can still tune remotely, but you have to either install an aftermarket wideband (innovate sensors will link directly with the Uprev software so you can log) or just flash a base tune and call it good. Not perfect but gets you close.
Old Oct 14, 2021 | 10:47 AM
  #144
Scorpi0's Avatar
Seymore, I keep hearing pretty soon theyre gonna come out with a new emissions testing machine that will be able to tell if the stock ECU programming has been altered. If it detects its not a stock tune, your car will fail emissions. Will the Uprev tune make it impossible to pass smog?
Old Oct 14, 2021 | 10:50 AM
  #145
seymore4's Avatar
m56
I don't know anything about a new machine but I have heard reports that some people are failing in CA just from a flashed ECU, even when they're running a completely stock file. Only in CA tho. But the way things are going pretty soon they're probably just going to start failing everyone who isn't electric
Old Oct 14, 2021 | 05:34 PM
  #146
Scorpi0's Avatar
Yeah its probably not a new machine. Just a more advanced software.
Any idea if the Uprev tune will pass or not?
PS: California is a piece of **** trying to chase fairytale dreams. Did u hear pretty soon theyre not gonna allow any new sales of gas powered lawn equipment? Idiots!!
Old Oct 14, 2021 | 05:46 PM
  #147
seymore4's Avatar
m56
If they are detecting ANY alteration of the factory ECU programming then yes ANY aftermarket reflash will fail. My advice? Just capture a unicorn and lock it under the hood. That should be alright. Or maybe a Kardashian?
Don't get me started on the off road gas engine ban... which is not only completely impracticle but will ONLY hurt poorer small business owners (lawn care, mainly immigrants) and home owners. Ya'll supposedly got a drought going on down there for years, but this spring when I drove through beverly hills, they had the sprinklers on for so long it ran out into the streets. Drive up to the bay through Mountain View, Palo Alto? Its as green as jurassic park. Makes you wonder about what you hear the people in charge saying.
Old Oct 14, 2021 | 11:02 PM
  #148
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The small engine ban doesn't go into effect until 2023, plenty of time for people to repeal that madness.
As for the UpRev tune, can't you flash back to a 100% stock tune, put the license back on the cable, pass emissions, then put the UpRev tune back on the car?
Also, does this emissions law only apply to vehicle newer than 25 years old? The G35 is only 7 years from that point so....
Old Oct 15, 2021 | 10:01 AM
  #149
seymore4's Avatar
m56
As of April this year Uprev does not allow you to go back to stock and remove the license. They've switched to a 1 license 1 ECU policy which is on par with all the other tuning companies
Old Oct 15, 2021 | 11:30 AM
  #150
cleric670's Avatar
BANNED!!!
Hmm, well I suspect they'll have some kind of workaround/revert in the future so they aren't losing the large California market. Same with all tuning companies.
Hopefully anyways.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
