Uprev Q&A
Old Oct 17, 2021 | 02:32 AM
  #151
ErikNYC's Avatar
Exclamation
Originally Posted by seymore4
As of April this year Uprev does not allow you to go back to stock and remove the license. They've switched to a 1 license 1 ECU policy which is on par with all the other tuning companies
Wow! I didn't know that.
Old Oct 17, 2021 | 11:51 AM
  #152
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
An actual viable option then would be to just keep a second ECM/BCM on hand and swap them out for your emissions test.
Old Oct 17, 2021 | 03:51 PM
  #153
Scorpi0's Avatar
This might be the best option.
Old Oct 18, 2021 | 11:02 AM
  #154
TeddYang's Avatar
Ohio G Club Member
Anyone know of a spot or person in socal with a cable i can borrow to flash my ECU back to stock? I need to get my car smogged so can confirm if flashing the ECU back to stock will work or not.
Old Feb 28, 2022 | 09:20 PM
  #155
RecklessV35's Avatar
Low and Slow Loud and Proud G35/V35
Question about uprev cable
Soo I have a tractrix ob2 cable i used to use for the evo it would do all the same features if not more then the uprev cable and works really well with ecu flash my question is will it work if I by the uprev license or what would I need to be abel to use my tractrix obd2 cable to tune my g35?
Old Feb 28, 2022 | 09:41 PM
  #156
seymore4's Avatar
m56
An uprev cable is required to use their software. It has security coding in it that unlocks the software.
PM me I can set you up with whatever you need
Old Feb 28, 2022 | 10:15 PM
  #157
pm'd
Old Sep 5, 2022 | 12:43 AM
  #158
Boyd916's Avatar
VHR swapped 6spd sedan
can you pm me when you get a chance? It won't let me pm you i guess lol
or just email me. My email is my username on here @gmail
Thanks
Old Sep 5, 2022 | 09:42 AM
  #159
cleric670's Avatar
BANNED!!!
Tagging @seymore4 to read previous post.
Old Jan 20, 2024 | 02:27 PM
  #160
conkerbrain's Avatar
G35 6MT
I have an 03 G35. I see in one of the posts above that some 03 do not have tunable ECU. How can I verify that mine is tunable? I'm planning on installing HFCs, catback, and plenum spacer and want to datalog to verify AFRs are in range. Looking for the DIY tuner kit (assuming it will work with my ECU). I know that I will need a wideband 02 sensor since I have an 03. Which brands of wideband integrate well with uprev? I assume you just plug the wideband USB into the laptop and the uprev software integrates for logging. Thanks.
Old Jan 20, 2024 | 03:00 PM
  #161
seymore4's Avatar
m56
If you have a coupe they are all tuneable, but you have to relocate one of the pins in the OBD2 plug.
If you have a sedan you need to look at the physical ECU and see which one you have. See the attached picture.
Get an innovate wideband
Old Jan 21, 2024 | 03:08 AM
  #162
808HerbzG35's Avatar
sorry, i didnt know anything about wideband til you brought it up. I would email and ask uprev for accurate answers. I usually just monitor my live parameters using Torque smart phone App and OBDLink MX hardware. Good luck
Old Jan 21, 2024 | 11:29 AM
  #163
seymore4's Avatar
m56
This only affects the 2003 models; 2004 and newer have factory widebands that we can monitor and record with the Uprev software
es_bayy
Oct 23, 2014 01:28 AM
BearPaw
Apr 3, 2014 07:41 PM
GT-ER
Engine - Power Adders
Dec 6, 2010 09:44 PM
GrayG35
Tuner & Dyno
Jun 28, 2008 04:54 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
