Uprev Q&A
Old Jan 2, 2020 | 08:33 PM
  #106
Django Daponte's Avatar
G35x awd
Tuning the comouter questions
By buying the 775 package the 1 reflash license is that in just you get to tune your car once and the license expires or is it a license you get to kewp on one computer and you get to tune as much as you want with that computer. Also what functions are you able to control. Can you turn off abs and traction control ect...
Old Jan 2, 2020 | 11:30 PM
  #107
seymore4's Avatar
m56
You get 1 license to tune 1 car. Once the license is flashed onto the ECU you can retune it as many times as you want, and you can also buy additional licenses so you can tune multiple vehicles. I'll shoot you a PM, I can help you out.
Old Jan 3, 2020 | 10:18 AM
  #108
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I was told by my tuner my Uprev license was good for my car and any other Infiniti I buy.
Old Jan 3, 2020 | 10:33 AM
  #109
seymore4's Avatar
m56
You can use it on any other supported vehicle (Nissan or infiniti), but you have to flash the first car back to stock and remove the tune first. It can only be used on 1 vehicle at a time
Old Jan 3, 2020 | 02:19 PM
  #110
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I'll have to clarify what my tuner said then. What I was told is its good for any infiniti/nissan vehicle I own, they didn't say anything about it being just one vehicle at a time. Not that I have any current plans to tune anything else right now though.
Old Jan 3, 2020 | 02:24 PM
  #111
seymore4's Avatar
m56
No need to clarify anything, I am 4000% certain that's how it works.
Old Jan 3, 2020 | 05:19 PM
  #112
G2B35AGN's Avatar
I think he meant he needs to go back and straighten out his tuner.
Old Feb 14, 2020 | 03:50 PM
  #113
deuce189's Avatar
Infiniti G35 coupe sport 6mt
Is there any reason to assume that those aftermarket HVAC radio install kits if not wired properly could cause an issue with communicating with the ECU since the wire harness daisy chains through it... i remember reading that the wiring wasn't the same for every year G35 for the HVAC and thought i remember reading that on 03-04 the pin out is different for the 05-07 when plugging in the aftermarket HVAC... i'm starting to wonder if that's ****ing up my OBD2 to ECU communication...
My car was at SOHO and they were able to bench flash it fine so the ECU isn't not bricked and they tested all the read outs for all the pins on the OBD2 so they said it's getting signals just something along the wire run through the daisy chaining of the harness is fudged up somewhere.
Old Apr 13, 2020 | 01:03 AM
  #114
j_mullet's Avatar
Looking for etune
Hey there. I'm looking for an uprev guru. Ive got the cable and license already. Do you work for uprev? What cost is a retune, if you do tuning? Let me know thanks.
Old Apr 13, 2020 | 11:02 AM
  #115
seymore4's Avatar
m56
I will send you a PM
Old Apr 14, 2020 | 11:34 PM
  #116
NandoG35's Avatar
Lowered, grey,
New to the g35 family
Hello everyone, I’m new to All this so let me explain, I bought a 2004 g35 with an aftermarket exhaust (straight pipe) and also with an aftermarket cold air intake. I took it to the mechanic and he suggested I get a tune. I was looking around and came across someone selling an uprev tuner, he says That in order for me to use it I will need to buy a license but I don’t understand what that is exactly so could someone explain to me everything I need to do I order for me to be able to tune it. Thank you
Old Apr 15, 2020 | 09:56 AM
  #117
seymore4's Avatar
m56
There are 3 components:
1) the actual tune file which is created by a tuner (or yourself if you are the DIY type)
2) the license which unlocks your ECU and allows the tune file to be installed on your ECU. Think of it like Microsoft office. You need a license to use it on your computer. Same thing with Uprev. 1 license per ECU to tune.
3) the reflash cable which is used to communicate with the ECU and access the Uprev software
There are 3 types of reflash cables:
1) standard ---only lets you upload tune files and datalog for remote tuning
2) tuner ---- everything standard does plus gives you access to the actual tuning programs yourself
3) pro tuner--- for professional tuners
Shoot me a PM I'll set you up
Old Apr 15, 2020 | 11:57 PM
  #118
Scorpi0's Avatar
I probably shouldnt be asking this here, but cant someone just hack and bypass the licensing part of this tuner?
Old Apr 23, 2020 | 01:38 PM
  #119
SwampCzar's Avatar
G35 Sedan, 6MT, Plenum Spacer, Tanabe Cat back, Z1 high flow cats
This is what I have read elsewhere also, however when I got my G tuned in Feb 2020, the tuner said they no longer allow to reflash back to stock and remove the tune to be able to use it on a different car. Thought it was strange.
Old Apr 23, 2020 | 02:08 PM
  #120
seymore4's Avatar
m56
They lied to you. Probably are looking forward to selling you another license in the future.
There is a set procedure you have to go through to get the license back, but it is very possible... I do it all the time
https://www.uprev.com/secure/support/
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
