Uprev Q&A
Old Jul 3, 2019 | 10:29 AM
  #91
seymore4's Avatar
m56
Originally Posted by LoSt180
You are not correct. EcuTek is another popular option.
Ecutek only supports 2009 and newer 370/ G37's. For the older G35/350z's UPREV is pretty much the only game in town unless you want to break the bank and go full on fast n furious
Old Jul 17, 2019 | 01:47 PM
  #92
Brandon Burgess's Avatar
its the 2005 Infinity g35x with 143k
UpRev tune
How’s it going I believe my mats system is messed up in my 2005 infinity g35 I’d like to fix this ASAP how soon can I flash my ECU?
Old Jul 17, 2019 | 01:51 PM
  #93
seymore4's Avatar
m56
As soon as you get a reflash cable. I can overnight you one if you're in a real hurry, shoot me a PM
Old Jul 17, 2019 | 06:34 PM
  #94
Is there somewhere I can get one?
Old Jul 17, 2019 | 07:36 PM
  #95
seymore4's Avatar
m56
I got you.
Old Sep 10, 2019 | 11:59 AM
  #96
deuce189's Avatar
Infiniti G35 coupe sport 6mt
i got a question for ya... been trying to diagnose this issue on my 2003 Greddy Twin turbo g35 for a few months now. I ended up ordering my own cable and i'm able to duplicate the problem if i attempt to reflash the ecu with the current rom for the tune i'm running now. Car has been turbo charged since before uprev was even a thing, it was running a turbo xs piggy back that the previous owner had removed and then flashed with uprev instead. Can't seem to get a straight answer if they originally bench flashed the car when they switched to uprev or not. As of now nothing can be done through the OB2 port which is a pain for a car we are planning really making several changes to and retune.
Pin was already relocated. And if this is also an indicator... previous owner did swap the radio which is using a after market radio dash kit. I wasn't sure if that could interfere since the obd2 harness runs through the radio between the ECU and ob2 port.
Another thought is if my ECU is just bricked, and i need to look at getting another one to flash too.
Old Sep 10, 2019 | 01:21 PM
  #97
Urbanengineer's Avatar
Good luck Joe lol.
Old Sep 10, 2019 | 10:19 PM
  #98
seymore4's Avatar
m56
My guess is something funky with the wiring. The ECU is NOT bricked; if it was the software would not detect it and your car would not run.
Old Sep 10, 2019 | 10:45 PM
  #99
deuce189's Avatar
So many things spliced from the gauges and old piggy back. Bleh. I feel like I need to replace the whole wiring harness.
Old Sep 11, 2019 | 06:45 AM
  #100
Labor of love!
Old Sep 11, 2019 | 10:44 AM
  #101
deuce189's Avatar
I'm wondering if maybe the Pin from where it was relocated isn't seated properly or isn't making good contact. Know of any tricks or remedies for that?
Old Sep 11, 2019 | 11:21 AM
  #102
seymore4's Avatar
m56
Pull it apart and check the wiring
Old Nov 7, 2019 | 05:37 PM
  #103
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Moderator moved to the appropriate thread.
@06RevUpCanada
I've never had a person say the tune was not worth it after they did it
Seymore, what is this factory throttle limit I’ve been reading about? I’m looking into a tune since I put hfc on my g a couple months ago.
Old Nov 7, 2019 | 06:39 PM
  #104
seymore4's Avatar
m56
There is a limiter on the electronic throttle from the factory, the first thing we do in the tune is fix that. Makes the car much more responsive and peppy.
Old Nov 7, 2019 | 11:51 PM
  #105
Scorpi0's Avatar
What does this limiter actually do?
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
