Automatically process the Navi OK screen
Old Apr 30, 2008 | 02:41 PM
  #211
finagle69's Avatar
Originally Posted by KPierson
Yes, I would agree. As long as you don't mention any modifications that would allow video to be displayed on the front screen while moving there shouldn't be any issues. Since this module doesn't allow video they shouldn't have a problem with it.
If there is enough interest over there KPtechnologies will have to look in to sponsoring them, too.
OK, i'll do up a nice review thread over there soon.
Old Apr 30, 2008 | 04:00 PM
  #212
KPierson's Avatar
I would appreciate it!
These should be here very, very soon. I've got my guy making a large batch of reverse mirror tilt modules right now, but as soon as these boards get here I'm going to put him on these.
Old Apr 30, 2008 | 07:00 PM
  #213
07G35Socal's Avatar
One thing to note on the 08' G37 install I did. With cars that have the iPod adapter in it. When an iPod is connected it takes the interface a little more time to boot up the iPod interface and get to the "OK" screen. So I would recomend that if you use an iPod a lot in your car that you setup the dial on the module so that it is timed to send the "ok" signal with the iPod connected.
Old May 2, 2008 | 03:48 PM
  #214
finagle69's Avatar
Kevin,
I ran into an issue yesterday and again today. Upon first starting the car in the morning, the ENTER (OK) button does not function for a handfull of minutes. I'll try to describe exactly what happened.
First turn the car on, the bypass does not function (does not press OK).
Pressing the ENTER button has no effect on the system. (as a side-effect, the BACK button does not function at this time either)
Pressing the SELECT button on the steering wheel works and allows use of the system.
During this time, the NAV bypass is IN EFFECT. Meaning, if i navigate my way through the menus with the SELECT button, I can issue a STREET ADDRESS input while moving.
Both yesterday and today I periodically pressed the ENTER (OK) button and after 10 minutes yesterday and 5 minutes today, the Relay clicked to the initial state and ENTER (OK) button functionality returned.
After this, the system behaves as one would typically expect.
I'm trying to wrap my head around what the possible problems could be. any suggestions?
Old May 2, 2008 | 05:39 PM
  #215
KPierson's Avatar
When you get a chance try something out -
When everything is working "normally" hold down the "OK" button and then press the "BACK" button and see if the "BACK" button works.
It obviously sounds like the output is turning on and staying on at start up for some reason - possibly the module isn't initializing correctly.
Old May 2, 2008 | 09:56 PM
  #216
finagle69's Avatar
holding OK, back does not work. in fact, no buttons work while holding OK, which i'd assume is normal operation?
Old May 4, 2008 | 10:53 AM
  #217
KPierson's Avatar
I would assume that would be normal as well.
When the module locks up though all other buttons besides "back" still work?
Old May 4, 2008 | 06:22 PM
  #218
finagle69's Avatar
yes they do. im going to play with the delay dial. maybe i have it set too low.
Old May 5, 2008 | 05:31 PM
  #219
finagle69's Avatar
Did it again this morning. I'll take it all apart and inspect the wiring just for good measure. Other than that, i'm not sure what else I can do.
Old May 6, 2008 | 11:26 PM
  #220
KPierson's Avatar
If the adjusting the timing doesn't fix it, and the wiring looks good shoot me an Email and I can send you a replacement unit. I'm guessing there is something wrong with the module itself as you are the only one experiancing this problem, and the problem is inconsistent.
The production circuit boards shipped out today. I should have them early next week and at that time I will be setting up a release thread to offer these at a special introductory price (10% off).
Get ready!
Old May 13, 2008 | 03:49 PM
  #221
finagle69's Avatar
/me knocks on wood...
My issue hasn't occured in the last three days.
Old May 13, 2008 | 04:24 PM
  #222
finagle69's Avatar
Review posted on MyG37.com
http://myg37.com/forums/showthread.p...07#post2333507
Old May 13, 2008 | 04:26 PM
  #223
KPierson's Avatar
The boards showed up today! I haven't had a chance to play with them yet, and probably won't with ZdayZ this weekend.
They look good, hopefully they work good too!
Old May 16, 2008 | 07:48 PM
  #224
cnugs127's Avatar
Kevin, just out of curiousity, how many people have expressed interest in purchasing this module?
Old May 18, 2008 | 10:34 PM
  #225
KPierson's Avatar
I would estimate it to be around 20 people or so.
For those 20 people, this module is NOW available through out website!
Under the products page click on the Navigation Interface and then select Navigation Interface.
The MSRP is $99.99 but we are offering a special introductory price of $89.99 for the next two weeks. After the two weeks are up the price will be $99.99.
If anyone has any questions please let me know!
