Anyone try this yet? v. Car Audio
Old Apr 11, 2008 | 07:41 PM
krazzyguju's Avatar
I tried searching for this but nothing came up. Has anyone tried replacing the rear factory subwoofer with a aftermarket subwoofer and adding an amp as well somewhere in the trunk? What would be some cons to this or would it not be possible? Im thinking about doing this. I want a subwoofer and an amp in the car but hate the idea of losing trunk space because I use the trunk space all the time.
Old Apr 12, 2008 | 12:59 AM
CoppellStereo's Avatar
you might need to reinforce the rear deck as well as get a sub that is a free air sub
Old Apr 12, 2008 | 01:58 AM
stanfna's Avatar
you may want to look into these...
http://mobile.jlaudio.com/products_s...hp?page_id=245
Old Apr 12, 2008 | 12:10 PM
07IMLG's Avatar
i had the non prem n put a 10 in sub in the rear deck w/ a amp, but it doesnt sound really good. so i took the 10 out and put 2 12s sounds a lot better and cleaner.
Old Mar 31, 2011 | 09:32 PM
botlfed98's Avatar
so nobody on here has had success with removing the factory sub and replacing it with an aftermarket in the rear deck?
Old Mar 31, 2011 | 09:40 PM
zoop425's Avatar
Its not worth it because any free air sub that size that will fit there wont sound good. You will have better luck getting a box build to fit under the liner and have the sub face the opening
Old Apr 1, 2011 | 05:24 PM
jimboG35x's Avatar
same thing hear i dont wana loose the trunk space either.i rather replace the rear sub on my bose and replace the door speakers...
Old Apr 1, 2011 | 05:46 PM
dohturdima's Avatar
I have a narrow profile box with a 10' kicker sub in it, and a pioneer amp right behind it. It takes up a bit of trunk space but not the amount I cannot live with. I wanted to go the free air route initially but the installer was able to dissuade me from going that route claiming it would not sound nearly as well.
Old Apr 5, 2011 | 02:53 PM
dsgb73's Avatar
Veteran: Navy
The shop I go to had a good suggestion for running an aftermarket amp with the install subwoofer. Depending on budget you may want to look into a Audison amp (LRX 4 possibly) that is capable of running interior and sub woofer while also adding in a Bit Processor of ome sort for tuning the entire system, front and rear fill speakers as well as sub. They did this install in a 07 Coupe and it sounds very nice. I did consider running aftermarket sub as well, but for what I want it's going to eat some of the trunk space.
hdmark
Apr 29, 2019 04:31 PM
mjfenix
Aug 17, 2017 05:49 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
newg37
Jul 26, 2015 09:32 AM
