Put Subs in now check engine light
Old Mar 28, 2009 | 04:15 AM
braddahjon's Avatar
Im confused. I installed my subs and now my service engine soon light is on and airbag light is flashing? Is it because i opened the b pillar bottom to run wires? on removed the rear seats???
Old Mar 28, 2009 | 05:32 AM
rustyeleio's Avatar
Wassup Bradahjon,
I am just guessing but maybe the place you tapped into is feeding the air bag or the BCM? Check the fuse if it blew and try chaning the location that you tapped into if you tapped directly into the fuse panel. This is based on your earlier post for a tap point.
By the way, did you splice or use one of those fuse expansion adapters (Littelfuse Add-A-Circuit)? Not preaching just that those add a fuse are pretty friggen' cool since they are 100% removable which may be helpful.
Again, just a guess...good luck.
Old Mar 28, 2009 | 08:45 AM
kregg's Avatar
try this:
https://g35driver.com/forums/tech-07...-flashing.html
I have seen cars do this when messing with wiring and the battery still hooked up.
G'luck!
Old Mar 29, 2009 | 05:29 AM
braddahjon's Avatar
Thanks Im gonna check it all tomarrow. I ran a air bag diag and this came up B1023 Cutoff telltale disconnected, line short, gnd short
Muski_G
Dec 1, 2023 11:11 AM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
