08 Sedan | Factory navigation | arrow tripping out
Old Apr 19, 2011 | 07:36 PM
D/\Rk Stoc|{er's Avatar
Lately, when I use the navigation, the arrow will start to spin around like a merry-go-round and lose its route. Then when it re-routes, it gives me a wrong route.
And on some occasions, the arrow will go off course and it'll look like I'm off-roading on the map!
Please H E L P ! ! !
Old Apr 19, 2011 | 07:48 PM
kool_yaar's Avatar
one person had a similar issue but he had done the nav bypass, it turned out that he forgot to plug his gps antenna wire back in behind the center console... maybe someone did some install or something or dealership opened up for some repairs and loosened the wire.... so the question is did you have any work done back there?
Old Apr 19, 2011 | 07:55 PM
No work ever done to the navi. I thought it might be because I never updated the software (for up-to-date roads/destinations), but I doubt it.
Old Apr 21, 2011 | 09:06 AM
RemmyZero's Avatar
well if you've never touched anything behind the dash then there are two options:
* your antenna is faulty
* the software is intermittently losing signal (seems less likely though since everyone else with this update is fine).
you can try re-updating the software (if possible) or rolling back to the old version and registering a complaint with infiniti but it sounds like you'll have to go visit them for this issue.
Old Apr 21, 2011 | 01:05 PM
kool_yaar's Avatar
no it cant be the software imo its a hardware issue, either a bad antenna or maybe even a faulty HD where its not able to read the map data at times.
Old May 12, 2011 | 02:54 PM
Thanks for the input guys! Guess I'll just have to ask on my next maintenance visit to the dealer. =/
Hope I don't get lost in the meantime! Haa
Old May 12, 2011 | 10:24 PM
kool_yaar's Avatar
^ lol, keep us posted with your outcome though for future reference...
Old Nov 18, 2013 | 06:36 PM
11/18/13 UPDATE | Finally fixed!! *crossing fingers
Sorry for the LATE update. Haven't been on the forums for a minute.
Navi is now working properly!! Here's a quick timeline of how things transpired:
I initially unplugged my car battery to "reboot" everything. It worked for awhile but not for long. I then took my car to the dealer and got the same dumbfounded responses as no one had ever seen this before. They updated my software but the problem persisted. Finally, they recommended to replace the navigation screen/hardware.
Fortunately, for unexplained reasons, my navigation started working all of a sudden! Not sure if the updated software took awhile to take effect. Or maybe it was from playing with the map display settings; I would change back and forth from "Bird's eye view" (which is the 3D-type view) to the one directly overhead (2D view).
I can't honestly tell you what is was that fixed it but I am just relieved that it is, indeed, fixed!!
tal1412
Nov 28, 2022 09:25 AM
Jusseth
Sep 13, 2020 12:25 PM
tiguy99
Mar 1, 2016 11:42 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
