Odometer Stopped Working
Old Apr 27, 2022 | 02:30 AM
Mike Litvin's Avatar
G35x sedan
08 G35x sedan, no nav
So recently I was having key fob issues and I posted about it here and ended up fixing it, so that is a plus. But on the road to fixing that, I ended up breaking something else, or it broke on its own, but I doubt it. So I have halo's that are wired up to a switch that gets power from the METER(BAT) fuse near the pedals. I thought this was interfering with my key fob, so I pulled it out and turn the car ON, I think this ended up either shorting or complete breaking the odometer. But I put the fuse back in and kept going on with life until I filled up, reset the odometer and noticed it was stuck at 0.
I tried checking the meter fuse to see if it was blown, it is solid, I tried redoing how I think I broke it, nothing, and I tried unplugging the battery for 30 seconds, nothing. I also tried a force clear, on the FIXD app, as it apparently resets the sensors, nothing. I also did try switching to the other Trip and resetting both again, but neither are counting anymore.
I noticed many people in other threads talking about speed sensors, and mine does indeed say OFF in the diagnostics mode, but my speedo works fine. Only reason I am fine and know that it says OFF is because I disconnected that wire from the head unit to allow my backup camera to function properly in the AUX mode a very while back.
Any ideas or suggestions?
Old May 6, 2022 | 10:17 PM
G35x sedan
Update, it now works on and off, but usually off.
YGNKnowledge
Aug 20, 2019 09:52 PM
monstrosity
Jan 27, 2015 04:49 PM
SergeantRed
May 14, 2013 06:08 PM
Retzius
Aug 29, 2010 06:54 PM
viguera
V36 General Tech Questions
Aug 30, 2007 12:18 PM
