Thinking about going back to stock springs...
Old Aug 27, 2008 | 03:40 PM
TheIvoryG's Avatar
I'm heavily debating going back to stock, and just wondering if anybody else is having the same struggles.
I'm trying to weigh positives and negatives to having springs, and feeling like the negatives are just out weighing the positives to them.
Positives:
Gap is gone.
Ride is better(personal opinion...but I think it is).
Handling is better(some of this due to -2* camber though).
Negatives:
Still no front camber kits. This creates huge tire wear issues(although I've got almost 14K miles out of my TR1s on this set), but even more it creates a tuck on all the tires that I just don't like. I'm not going to get the back camber kit until I can get the front one, so for now all my wheels are tucked which drives me nuts.
Shocks will blow here at some point. I don't know if there is a way to tell, but I can't see me getting more than 2-3 years on stock shocks with H&R springs?
Dragging: not the worst of my worries because I'm careful and used to it, but its still a negative. My front bumper definitely has a few scrapes from unavoidable driveways and such.
I am really scared about changing back and then the gap bothering me. I would want to keep my 19" coupe rims on, which only looks worse with a gap. I would probably go to a 45 series tire on the fronts to take some of that up, I saw another guy do that and it wasn't a horrible solution.
It's heavy on my mind right now because I need tires, and figure I should do all this at once if I'm going to do it. Any feedback and ideas would be appreciated...at worst thanks for letting me vent.
Old Aug 27, 2008 | 04:23 PM
sredish's Avatar
it'll look different to you at first, but you'll get used to it. do be prepared at first tho. I want so bad to drop it some but it's just not feasibly possible with the roads and areas I drive.
Old Aug 27, 2008 | 06:58 PM
JayJay's Avatar
Its all part of be dropped, you know those are some of the things your going to encounter dropping your car. Have you ever thought about coilovers, these wont solve your camber issues but they will solve your worry about shocks!
http://hrsprings.com/scripts/appguid...%20G35%20Sedan
Old Aug 27, 2008 | 07:04 PM
hji1945's Avatar
I have swift springs on my car.. And i just had to change tires.. I put on about 16k miles on it.. And front left tires were starting to split... I was in your same situation when I was changing tires, and I still am having same thoughts.. If you are just worrying about the gap, probably it won't bother you that much after few weeks.. On my Coupe I put on thicker tires on to close out the gap before, and I didn't like it because of the noise.. I mean after all everything it totally up to you.. I didn't change mine back to stock yet just cause I am lazy to spend time in my garage lately and it's hot.. HAHA..
Old Aug 27, 2008 | 08:29 PM
C6Zhombre's Avatar
16K sounds like good mileage to me...my first set of rear 325/30 goodyear runcraps on my c6z lasted 4400 miles. I bought another set when the ody turned 8600 and another set at 13K. factory fronts still look good
Old Aug 28, 2008 | 12:19 AM
hji1945's Avatar
Wow.. That's scary.. If I had to that many tires I will definitely go back to stock until I see front camber kit..
Old Aug 28, 2008 | 12:34 AM
AlterZgo's Avatar
Why not just get some Eibach springs instead of going back to stock? It would give you most of the benefits of the H&R. Plus, due to the more mild drop, your rims won't look as cambered.
I just installed Eibach springs on my G along w/ the rear camber kit. I have the rear camber set to -1 degree and the fronts don't look all that much more cambered.
In fact, you should PM ckp. He wants to get rid of his Eibachs to get some H&Rs. Maybe you guys can just trade.
Old Aug 28, 2008 | 01:08 AM
kool-aid's Avatar
if you sell pm me! im interested in some h&r's
Old Aug 28, 2008 | 11:44 AM
ckp's Avatar
ckp
Thumbs up
lol thanks for suggesting to him for the trade for me lol but actually i think i am starting to lean to keeping my eibachs....i have been gone to dubai for the past three weeks on vacation, and after i came back and saw the car settled i like it more and more every day, and i think ima just put on spacers and keep the springs, but we will see what happens.
Old Aug 28, 2008 | 12:51 PM
darnelled's Avatar
You could go back to the original shocks and use a slightly upsized tire to fill the gap.
Old Aug 29, 2008 | 02:34 AM
AlterZgo's Avatar
Slap those spacers on man. They look GREAT. I just put on my Eibachs w/ 20mm spacers at all 4 corners. Check it out:
Rears are camber corrected to -1 degree. In retrospect, I'd go with +25mm spacers at all 4 corners. Since the front camber cannot be corrected, there appears to be even more space up front than in the rear. No rubbing or any issues whatsoever.
TheIvoryG - Here's a thought - if you're that concerned about uneven tire wear, just pick up a pair of rear coupe 19s up front and a rear camber kit. That way, you will be running the same tire and rim sizes at all 4 corners and you can do full tire rotations. When the fronts go to the rears, they will wear evenly b/c your rears will be properly aligned.
This is another reason why I like the M45 19s.
Old Aug 29, 2008 | 09:03 AM
paulg35s's Avatar
I drive around nyc with my drop. I think we have some of the worst roads out here. I say suck it up and enjoy the ride. I don't think we really need a camber kit for the front anyway. =)
EnCr1pt3d
Jul 8, 2019 02:48 PM
apintojr
Jul 23, 2015 10:52 AM
Karnicle
Jul 23, 2015 05:08 AM
nascarbuff17
Jul 16, 2015 10:23 AM
