If the ride is floaty...
Old Feb 10, 2009 | 09:40 AM
soundmike's Avatar
Is that a function of the shocks, or the springs?
The G is a bit odd to me, at times it feels rather planted, but there are other times when it starts feeling floaty. I don't believe the shocks are bad, at least from the last time i checked down there.
Old Feb 10, 2009 | 01:13 PM
jerminator's Avatar
If it happened over time, then I'd say the shocks may have worn. If the car was like that from day one, then both could cause that feeling. Do you have the sport pkg? What tires? Stock or something else? Going to a different (inferior) tire can totally make the ride more floaty feeling.
Old Feb 10, 2009 | 07:14 PM
soundmike's Avatar
I'm the second owner, had it for about 10k miles now. It was fine until just this past week. I've had the aftermarket tires for the past 5k. Hmm...
Old Feb 10, 2009 | 08:22 PM
nghiars's Avatar
what type of tires and how many miles on the car? is it lowered?
Old Feb 10, 2009 | 08:48 PM
G35Now!'s Avatar
Moderation-free
Mike, I'd say tires; check your tire pressure, and look at the wear. We're in that weird Houston weather when temps cycle up and down, and pressure doesn't stay constant - at your mileage, I'd guess it's that vs. suspension.
Old Feb 10, 2009 | 09:46 PM
soundmike's Avatar
Thanks, guys. Pressure is right at 36psi on 245/40/19 FK425. Wear is also pretty even. I figured it could be from the temps, but then it could also be the shocks. It's a bit disconcerting at times.
Old Feb 11, 2009 | 04:15 PM
Lemodular's Avatar
Definitely shocks. Possibly tires. Probably not springs.
Old Feb 11, 2009 | 06:29 PM
E-Ticket Ride's Avatar
Springs wouldn't go bad, especially at your mileage rate (what is your total mileage now?). If you can easily depress the trunk/engine bay portion of your by pushing down with your hands, it's probably the shocks that are bad.
KruZZe
Feb 27, 2023 05:04 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
Fox843
Nov 7, 2015 05:43 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
