370Z springs experiment
Old Dec 11, 2011 | 03:37 PM
  #316
rpm&my_G35's Avatar
Originally Posted by turrific
I just removed my summer wheels after having installed the front 370Z springs ~6months ago in May.
Evaluation so far: no scraping, happy with the stiffness, handling. But, I did notice abnormal tire wear (cupping) on the inboard sides of the front tires when I took them off. This is due to the increased negative camber (now -1.4 to 1.7°). I've noticed that it does seem to sit a bit lower than a G35s or Xs when side by side.
Have any of you noticed the same issue? Our front suspension has no camber adjustment. Is there some way to avoid this without getting a camber kit, which I'm assuming isn't cheap?
No not really. There is a new 'group buy' for good SPC camber kits. It's less expensive than new tires and you could easily resell a used camber kit down the road, if you decide to sell the G and don't need the kit any more.
https://g35driver.com/forums/canada/...group-buy.html
Old Jan 5, 2012 | 08:44 PM
  #317
G-GROOVE's Avatar
will the Z breaks work on a sedan?
Old Jan 5, 2012 | 08:48 PM
  #318
2GoRNot2G's Avatar
What year Z and what year sedan? If your refering to the 370Z sport brakes and if they will fit a V36 (2007+) sedan... then yes they will bolt right on without any brackets required you will just need to trim the rear dust shields to clear the larger rear rotors.
Old Jan 5, 2012 | 08:52 PM
  #319
G-GROOVE's Avatar
07 sedan well i have rims on my car will i still need to trim
Old Jan 5, 2012 | 09:09 PM
  #320
2GoRNot2G's Avatar
The dust shields I am referring to are for the rear brakes, so they have nothing to do with having aftermarket wheels. You will still need to trim the factory rear dust shields in order to clear the larger rear rotors. They are easy to trim, though... All you need is a good pair of tin snips and some sand paper to smooth out the rough edges so you don't slice yourself open on them afterwards.
Old Jan 5, 2012 | 09:16 PM
  #321
G-GROOVE's Avatar
so the new sport breaks on a g37 sedan should work as well right
Old Jan 9, 2012 | 04:28 PM
  #322
drivethefive's Avatar
Any of you guys have pics of your 370z spring set up w/ aftermarket wheels?! Trying to figure out tire size now that I'm dropped on mine. I know I"m going to have some wheel gap left so I'm trying to figure out if I can minimize some of it by going with a 40 profile tire instead of a 35. Going w/ 19's btw.
Old Jan 10, 2012 | 03:18 PM
  #323
funkydrummer's Avatar
Why are people choosing these over the Eibach Prokit for the X? Cost? Slightly higher ride height?
Old Jan 12, 2012 | 11:21 PM
  #324
^ slightly higher than Eibach's so you still have clearance but get rid of some of that 4x4 stock look that the X's have. I'd say this drop is comparible to the Impul's but much cheaper than paying for Impuls. Still rides great too as well as obvious improvements in cornering.
Old Aug 30, 2012 | 10:26 PM
  #325
Viet2100's Avatar
I know this thread has been beaten, but if anyone is wondering, stocked revised Z springs (2004.5+) will fit of course and the spring rate is much closer to the G35S. Here's mine, 18 months later and 55k miles later:
I have about 3" of clearance.
Old Aug 8, 2019 | 03:56 PM
  #326
puddin"'s Avatar
Q50S AWD 3.7
RESURRECTED FROM THE DEAD!!!
I am going to be doing this mod to my 08 g35x. I have some rear 370z springs with 2 green and 1 pink dot on them. Should i get 03-09 350z front springs? or should i look for 370z front springs? Which color dots should i look for? thanks all
Old Oct 24, 2019 | 01:12 PM
  #327
Hall Stevenson's Avatar
Considering doing this as well. It appears that there's only (2) aftermarket options for AWD models, from Eibach or Swift, and they both do 1.3 to 1.4" drop in the front and 1" in the rear and that much (especially for the front) may require aftermarket camber kits and that's what, another $500 ?
For the 370Z springs, what years will work ? I don't want to presume springs from an '08 '09 370Z will fit an '08 G35X without confirming.
Tbrown930
Feb 13, 2016 12:13 PM
mj_39
Mar 22, 2010 02:46 PM
viceversa
Mar 20, 2009 08:12 PM
coolbreeze
Jun 27, 2008 10:09 PM
GBoy
Oct 25, 2006 09:11 AM
