VDC light & SLIP light ON,added brake fluid , no help !!!!!!
Sep 24, 2009 | 03:40 AM
  #31
Quote: not lowered, stock everything. car is bone effin stock !!!
Front disc seem warped, or tires are feathering though.
dealer turned disc, but whop, whop, whop sound is still there.
my front brakes or tires are making this sound, "
whop whop whopwhopwhopwhopwhop "
dealer said tires are feathering, WTF #2
DOMO let me do my WTF dance here
Christopher,
Back to this sound. Is it there only when you put on the brakes or all the time to some extent?
If your tires are the same front to back move the backs to the front. This is why I mention this:
I purchased a car (not a g) which had what appeared to be a bad alignment on the front end. I took it into a tire shop (Goodyear) which provided the OEM tires. The tire dealer spoke of problems with certain tires on this particular car and moved the rear to the front with new on the back. This made a change but the issue did not go away. He then replaced the fronts. Total cost to me was $100 for 4 new tires which were suppose to be about $150 each. Problem went away. What was stated is that the OEM tires had an issue with 'belt shift'. Tires looked great on the outside but had an internal flaw.
Now the issue you mention has been noted by many with alignment problems. If this is ABS related then it could be triggered by a bad alignment or even with a bad tire (either new or old). Since the fronts seem to be feathering from your statement it may well be worth looking in that direction. No amount of turning of your rotors will fix a bad alignment or a bad tire. If a bad tire on the front then moving a rear tire there may well make the issue go away or at least change. If you decide to move a rear tire up front then do so one at a time so it makes it easier to figure out which tire is bad if that ends up being the case.
Reply 0
Sep 24, 2009 | 07:02 AM
  #32
Quote: I'll add
d) will the pill fix my slip light & vdc light ?
e) if not revert to,please leave my thread.
f) see (e) if you didnt understand (d)
now, once again, my wtf dance.DOMO
If you have to ask D it's no wonder you need help.
I'm having too much fun watching you blow up to leave this thread.
G/L with finding a dealer to fix the problem.
Reply 0
Sep 24, 2009 | 07:26 AM
  #33
Guys it's pointless trying to help this dude....
It's apparent all he wants to do is blow off steam.
Reply 0
Sep 24, 2009 | 01:35 PM
  #34
WOOOOOOO-WOOOOOOOO
did someone call a WHAMbulance ?DOMO
Reply 0
Sep 25, 2009 | 01:42 PM
  #35
Should we make the call?
Reply 0
