Shudder at 40mph (~60km/h)
Old Jul 14, 2010 | 02:28 AM
  #166
tg1234's Avatar
I would not call it waste. I need something the time I think I need. Not whn you driv it spirited for few minutes and than it turns to more agressive. But what if I just have the rush to speed for 2 minutes.
Sure it would be better with adjustable suspention and all but I would be happy with 5 map at my finger tip. Heck would be happy with 3.
My .02
Old Jul 14, 2010 | 08:25 AM
  #167
rpm&my_G35's Avatar
You already have 3. D, DS and MDS. lol
Old Jul 14, 2010 | 10:12 AM
  #168
heynow's Avatar
Anywhoo, getting back to the topic.
I got my car back from the dealer, they looked @ the shudder complaint & couldn't duplicate it. The service advisor drove it, the master tech drove it (again after my test drive with him). The tech also "ran diagnositcs" on it & found no sensors out of spec.
They were nice enough to address my other issues such as the weather stripping (replaced on all 4 doors via the ITB 037034C), and they also replaced the A/C compressor. So i'm very happy with the customer service i've received so far.
I'll keep you all posted if the shudder comes back - since no one has been able to reproduce it (even me) (knock on wood). It'd be funny if an $8 bottle of fuel injector cleaner was the solution!
Old Jul 14, 2010 | 11:08 AM
  #169
rpm&my_G35's Avatar
Do you have a copy of that TSB ITB. I can't seem to find it on the website:
http://www.infiniti-techinfo.com/TSB...px?tsbType=TSB
BTW - isn't something wrong when the Inifiniti site doesn't list the 07 G35 Sedan as a V36? It just says G35 (V36) 08. Am I missing something?
Old Jul 14, 2010 | 03:55 PM
  #170
heynow's Avatar
Sorry dude, that's what it says in the receipt
Old Jul 14, 2010 | 09:11 PM
  #171
ez-g's Avatar
[QUOTE=johnnyzee;4600505]Hey guys, I need some help...please.
The car "shudders" while cruising around 40mph (60km/h). It's intermittent, not always doing it, but does happen daily, and often enough to make me go nuts trying to figure it out.
Going back to the OP. I didnt read many of the 177 posts in between so hope this is not duplicating something already covered. But I very recently had a very similar sounding problem with my wife's '05 Pathfinder. At about 40 mph vibration, almost felt like driving on the rumble strip on the shoulder, plus hard dropping into lower gears. This was intermittent, and seemed to happen on either gradual up or downgrade, when the trans wanted to shift from 4 to 5, or 5 to 4. Problem was that the radiator failed and allowed the coolant and AT fluid to mix. The AT fluid was very cloudy and orange, not clear and dark red. Also had AT fluid floating on top of the coolant in the radiator.
In searching the internet I saw this is a well documented problem in 05 and 06Pathfinders, and many reported needing to replace the tranny and radiator. I changed the radiator and flushed the tranny, which solved the vibration problem, but hopefully no permanent damage occurred. Don't know if it pertains to the G, and I would hate to be alarmist. Just throwing this out there to create awareness in case a similar problem exists in the Infiniti.
Old Jul 15, 2010 | 12:44 AM
  #172
Toddwilliam1's Avatar
I had an 06 g sedan automatic that had a shudder. Turns out it was the valve body. Dealer replaced under warrenty and it never happened again. Ask to take one of the techs for a ride to show them, it worked for me.
Old Jul 15, 2010 | 09:46 AM
  #173
heynow's Avatar
yes, we're aware of the 06-early 07 VB issues, but i've taken the tech for a 15-min ride & coudn't even reproduce the problem myself. My service adv. & tech test drove the car later on only to find no shudder.
Old Jul 15, 2010 | 01:07 PM
  #174
johnnyzee's Avatar
Yeah it's tricky, it's not happening 100% of the time, and not hard enough of a vibration to really stand out as to what the problem could be.
My reflash is still holding up ok, haven't really felt the vibration since.
Old Jul 15, 2010 | 02:47 PM
  #175
NBYOND's Avatar
What build dates were affected with the cheap chinese valve body?
Old Jul 15, 2010 | 09:16 PM
  #176
heynow's Avatar
sorry dude, i wish i had the TSB
I think it really involves the 06s more than the '07
Old Jul 16, 2010 | 03:24 PM
  #177
heynow's Avatar
Yeah, i just looked over my service history, and my car had the TSB applied in Febuary o f 2009. So i guess that's the most current version.
Old Jul 16, 2010 | 03:43 PM
  #178
dohturdima's Avatar
Originally Posted by treacherous
My shudder was fixed with a the latest flash that became available a year or so ago. It slowly came back. I took car in for the 15+ quart auto fluid exchange and it is now back to normal.
Could you provide the # of the TSB? I hadn't had an ECU flash since the original throttle tip-in one. Or is it ITB08-017a (revised)? Thanks
Old Jul 30, 2010 | 09:01 PM
  #179
KMCG35X's Avatar
My 2007 G35X has the same issues described in the TSB for valve bodies, but it is not listed in the affected model range (only RWD). There are clearly transmission issues, and it sounds like ECU programing, Fluid change, and even the valve bodies are not fixing the problem. Before I read any of this, I was thinking it was the torque converter. It acts up most when the transmission is locking up or unlocking and I still feel something in 4th gear and at all different engine rpms.
I am fairly sure this is not a programming issue and the shudder and vibration are not consistent and see to be very physical in nature.
Has anyone actually nailed what is going on and had the problem totally solved with no remaining signs?
Has anyone received a new torque converter?
Does anyone work for Nissan and can share the real issue (I am sure they know)?
This is really concerning...
Old Jul 31, 2010 | 08:31 AM
  #180
taltek's Avatar
I've had this issue for a while now. I only detect when in auto-mode when the trans is in 5th and around 35-40 mph. Seems to search or ride the rpms way too low for 5th, but doesn't downshift. RPMs go down to 1500 or less sometimes. If i ride in 5th manually it's smooth. I brought it to the dealer i bought the car from. Tech validated the symptoms and I thought I'd finally get a resolution. Then I got a call stating Infiniti tech support wouldn't authorize a repair stating the car drives as expected.
I had planned to buy out this lease, but not getting this resolved has soured my opinion of Inifiniti service/support. Love the car, but I'm finding it difficult to accept this "trait".
