Dash Lights
Old Apr 27, 2010 | 08:52 AM
bsmsu2005's Avatar
Dash Lights
What causes ABS light and VDC Off but "slip" light off? Wheel sensor? YAW Rate sensor?
Old Apr 27, 2010 | 09:26 AM
AesonVirus's Avatar
Low brake fluid caused by pad wear.
Search through the tech section. There's a lot of threads on this subject.
Welcome to the forum, BTW.
Old Apr 27, 2010 | 09:29 AM
AesonVirus's Avatar
Old Apr 27, 2010 | 09:36 AM
G35Now!'s Avatar
Moderation-free
Thx AV
Old Apr 27, 2010 | 11:10 AM
kool_yaar's Avatar
Sticky it PLZ!!!!!!
Old Apr 28, 2010 | 11:18 AM
djfarhan's Avatar
Originally Posted by AesonVirus
thanks scott! ;-P
Old Apr 29, 2010 | 03:37 PM
AesonVirus's Avatar
Originally Posted by djfarhan
thanks scott! ;-P
Under the bus with all of ya!
Old Apr 29, 2010 | 07:43 PM
kregg's Avatar
+5 bazzilion on the sticky....
Old Apr 30, 2010 | 06:07 PM
bsmsu2005's Avatar
Thank you all for supporting each other in the assumption that I am dumb. I am an ASE mechanic. And had you read the post I put up it did not say anything about the BRAKE light or Cruise light and also that the slip light was OFF not really very close to the sympoms everyone assumed were wrong caused by brake fluid. Thanks for any serious help.
PS the brake fluid is full. Brakes are fine. VDC does not work at all and nothing changes if you unhook a wheel sensor. Is there anyway to self diagnose which sensor is the culprit?
Old May 1, 2010 | 10:56 AM
bsmsu2005's Avatar
Ok it was a wheel sensor the little clip that keeps the wire connectors together was broke so it was seperated about 1/8 of an inch problem solved.
Old May 1, 2010 | 11:17 AM
kool_yaar's Avatar
Since you are a ASE mechanic and we are not, does not make sense to ask us regular folks then...
Still i am glad you figured it out and posted your solution. You could have just tried the "assumed" solution that everyone suggested and come back and simply say thats not the issue, what next? Rather than highlighting our assumptive flaws and doubting our help...
Old May 1, 2010 | 12:57 PM
bsmsu2005's Avatar
I do appreciate anyones help on here and hope I can provide help to others, ASE doesn't mean I know near as much about the ins and outs of a G35 as someone who has owned one and modified or repaired it frequently
Plur
Interior
May 22, 2019 04:35 PM
deschutes606
Jul 18, 2018 09:34 PM
wonderizm
Sep 24, 2015 03:09 AM
06G35Kurtis
Aug 23, 2015 12:24 AM
